Squal when AC turned on
I have noticed that when I turn the ac on I get a loud squeal ,sounds like a belt slipping but the belt is ok.Turn the ac fan off and it stops,This lasts for 3-4 on-off cyles and then it stops. This only happens when I start with a cold engine and only with ac on.
Any suggestions Thank You |
Re: Squal when AC turned on
Sure the belt isn't glazed? There's a spray you can use on it to make it "sticky" again. Try that.
yeah, sounds like a dry/loose/old belt. Try the spray, if that doens't fix it, check the tension, and if it has 60k or 5 years on it, replace it.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
