Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-16-2006, 02:46 AM
jasim2005 jasim2005 is offline
please can anyone figure this problem out for me
my jeep is really causing my a lot of problems ... since I bought it I made alot of repairement for it .... but what to do I like it and I try to solve it's problems without thinking of selling it
the problem this time is that the check engine light would come on after 2 minutes for the first time and after it runs and turn it off and on immediatelt the light will come on , but if I leave it off for mre than 5 minutes it will not come till I wait for 2 minutes ...
can anyone please tell me about the fault ?
Thank you
Old 06-16-2006, 07:00 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: please can anyone figure this problem out for me
What year is the jeep.
Extract the codes and post them...
to extract the codes:
Turn the key ON, OFF, ON, OFF, ON
The CHECK ENGINE light will begin to flash out the codes, if your jeep is equipped with digital odometer the code will appear in the odometer (P????), The codes are in double digit form with a short pause between digits and a long pause between each separate code.
ex. | pause | | = 1 pause 2 - code 12
| | | | | pause | | | | | - 5 pause 5 - code 55
| = Check engine light flash.
Old 06-17-2006, 08:22 AM
thank you ...
I will post the number of flashes soon ... but my problem is that the engine light now takes longer time than before to come one >>>>
sometimes 1 minute to flah for the first time and then disapear so the engine will run .... so what can be the problem????
Old 06-17-2006, 03:19 PM
well if the CE light isn't coming on as soon as you turn the key to the ON position then it is either a bad CPS or PCM.
Old 06-17-2006, 10:44 PM
bringselpup's Avatar
bringselpup bringselpup is offline
Profile says it's a 93.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 06-18-2006, 01:28 AM
Well I didn't read the profile. And this could have been a different jeep that wasn't added to the profile.
Old 06-20-2006, 09:55 PM
The codes are :
| pause | |
| | | | | pause | | | | |
Mye be the codes show no problem but why does the Engline Light takes long only for the first turn on??? or if I leave the truck off for more than 5 minutes
The truck is running smoothly when it is ON .... the only problem is that I need to turn the key on the ON position and wait for about 1-2 minutes till the engine light comes .....then only the fuel pump and the spark (coil) will work so the engine can start ...
Old 06-21-2006, 01:01 AM
hardisk_c's Avatar
hardisk_c hardisk_c is offline
| <p> | | = 12; Battery disconnected w/in the last 50 starts
||||| <p> ||||| = 55; End of codes
Now, I'm paraphrasing the Hayne's Manual I have, but the gist of it is that the computer doesn't seem to think there's a problem. As dskob81 has mentioned, that coupled w/ the slow/non-existant lighting of the CE light @ startup would indicate either a dud PCM (computer) or the CPS (crank position sensor) is dying.
If it is the CPS, fredjacksonsan has already posted how do do an r&r of the cps on another thread here for a 2000 I6 and the manual I have (dated for 93 JGC's thru 2004) seems to indicate the position of the sensor has remained fairly static & that walkthrough should at least give you a heads-up on how to get this fixed.
If you plan on doing this yourself, I'd invest in some form of manual, personally recommending either the FSM or a Hayne's manual before going too much further.
Old 06-21-2006, 07:01 AM
If when you turn the vehicle on you aren't hearing that fuel pump right away I'm going to say it's PCM.
Old 06-21-2006, 07:14 AM
If the CE light doesn't come on, then the FUEL PUMP won't kick on, the Ignition Coil won't fire and the Injectors won't open.
This is all caused by the PCM not getting a response from the CPS = bad CPS or thinking it's not getting a response from the CPS = bad PCM....
Old 06-22-2006, 09:23 AM
that's right everything is not working till the engine light comes ON
by the way my jeep is simillar to yours ....
but when stop the engine and restart it immediately the light comes immediately .... it doesn't come on only if I leave it off for more then 10 ms
I have changed the CPS 1 and a half years ago ... it is still new ... and replced the disterbuter 6 months ago
Thanks to every one
Old 06-22-2006, 04:26 PM
It could still be the CPS, especially if it was an aftermarket brand (WELLS from autozone or BORG WARNER from pepboys and other part stores), if it is a mopar brand, then it is less likely to be an issue, but si still possible. The only other cause would be the PCM...
Old 06-23-2006, 08:30 AM
I have unpluged the CPS WIRE but it still comes late ... I can hear some noise comes from the computer ....
Old 06-24-2006, 12:36 PM
Like a very high pitched squealing sound?
Exactly what my PCM did before replacement. Once I got it going I could drive anywhere, but if I shut it off for longer than a quick errand I had to wait to get it going again. And as it got worse it took longer and longer before it would work. You can tell when it's ready to work, just sit quietly in the Jeep and wait to hear the fuel pump noise. Once you hear it then crank the starter and you will start up.
Old 06-26-2006, 08:03 AM
Yes, this is what is going on with me ... it is ok till I shut it down... I need to wait for till the engine light comes on ....
anyway from where can I get a second hand PCM ...? and how much is it??
Can this PCM be repaired???
Thank you bringselpup
