Old 06-16-2006, 12:47 AM
sthayer sthayer is offline
Passanger side floor borad heat
1984 Chevy S-10 Durango - wife is companing of the floor board getting extremely hot on the passanger side when driving - looked underneath - that is right where the catalytic converter is - any way to cut down on the heat - or am I possible missing a heat shield?
Old 06-16-2006, 11:21 AM
BLAZERBOY69 BLAZERBOY69 is offline
Smile Re: Passanger side floor borad heat
SOUNDS LIKE AHEAT SHIELD FELL OUT. CHECK YOUR LOCAL PICKNPULL FOR A REPLACEMENT
Old 06-16-2006, 05:06 PM
woody6725 woody6725 is offline
the cat could be clogged up too
Old 06-17-2006, 12:14 PM
RahX RahX is offline
I would be more inclined to think it was a bad cat.
Old 06-25-2006, 01:56 PM
ShadowHawk70 ShadowHawk70 is offline
I noticed the same on my S10 Blazer, and took it in to the shop that had installed the cat. converter about 5 years ago. They told me that the heat was from the cat. converter actually burning off excess fuel. They put a hole in the cat. converter with a cutting torch to inspect it, and it was glowing red inside - the honeycomb was not clogged up ata ll - but it was sure burning off some fuel (and gave the rotten-egg smell) - they told me that's usually an indication that the cat. converter is working very well, and is doing it's job. The bat part, now, though - is to find out why the engine is dumping fuel into the mixture to make excess enough to have to make use of the catalytic converter.
G'Luck!
Rex S.
