Go Back   Automotive Forums Car Chat > Bugatti > Veyron
Old 06-15-2006, 11:50 PM
Ziostilon Ziostilon is offline
Links to other specifics
I saw that in some other car section, there's a sticky with forums talking specifically about the brand or a specific car. So I was wondering if there are sites that discuss specifically about Bugatti Veyrons'.
Old 06-25-2006, 09:03 AM
murraydeschot's Avatar
murraydeschot murraydeschot is offline
Send a message via MSN to murraydeschot
Re: Links to other specifics
This is the place!!!
Unfortunately the Veyron forum here is a wee bit slow going so far, as there's not too much info available on the Veyron, aside from the info any Google search will kick up, and there haven't been too many road cars to break cover so far.
However, if you look at the McLaren F1 forum here I think you'll find that it is probably the single most extensive and exhaustive forum on the marque available on the 'net, with most of the cars produced fully documented, ownership traced, and anomilies noted. That part of the AF forum is probably the largest 'brains pool' on the subject on the globe. The expertise and knowledge of guys like Peloton25, hurstg01, mini magic, etc. on that particular section of AF has even extended, as far as I'm aware, to prospective F1 owners consulting certain active members in their pursuit to source F1s!
I'm sure that given time this part of the AF section will, I hope, prove a similar resource.
ALL (sensible) contributions gladly received!
You are not the owner of a McLaren F1 - You are her custodian!.
Old 06-25-2006, 07:51 PM
^^ what about the Koenigsegg and Pagani forum? Is AF the place for those too. Cause they're preety slow on info too right now. That is unless theres' not much info released on them
Old 07-13-2006, 05:20 AM
skiff's Avatar
skiff skiff is offline
There is some regular posting at http://forum.bugattibuilder.com
It also has a photo album, to be found at http://photo.bugattibuilder.com
Also, if you fancy, you can add some info pages into the Bugatti encyclopedia at http://wiki.bugattibuilder.com
You are all invited. Might you run into problems, you can contact me at herman at bugattibuilder dot com
Please note:
There are some issues with the server right now, but nothing too serious You should all be able to use all the features. I will configure a new server and transfer the data to the new server probably this weekend. (faster, and some configuration errors ironed out.)
www.bugattibuilder.com Your Bugatti resource. Types, scale models, books, WIKI, links.
Bugatti forum. Discuss Bugattis here!
Bugatti photo. NEW !!! Largest online Bugatti photo archive (11000 photos and counting). You can contribute too!
