Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-15-2006, 11:08 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
engine help please!!!!!
alright i rebuilt my talon and i used all grade A parts head studs hks gaskets the whole nine yards. now when i first got it back together it ran for a couple minutes and then it died and started doing what it was doing before the rebuild. which it would start and then die right after. now i checked the timing and its perfect everything is tight and connected. but still when i turn the key it just cranks and then it will start run at like 3k idle and then just die. any imput would be great cause it just boggles me i mean almost 80% of the car is brand new including the ecu
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 06-16-2006, 12:50 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: engine help please!!!!!
Sure everything is hooked up right? Check your harnesses.
If everything looks good, can't hurt for you to do a compression test. Than come back here and post the numbers. It will help us a little better in diagnosising a purely engine problem. But make sure your components are good, (IE coil pack, spark plugs, fuel pump, injectors etc. ) first.
1991 GSX 2.3 Stroker
Old 06-17-2006, 07:53 PM
alright my compression is 185 187 190 185, which should be great as far as i know. i check the fuel flow and it flows great, but when i checked for spark via the plug wires it had nothing. i changed the coil pack and stuff but still nothing wont start at all just cranks the fuses are all good.
any suggestions on what else to check electrical wise
Old 06-17-2006, 11:30 PM
defiancy's Avatar
Do you have a multi-meter or volt meter or whatever. So you can check current to see if you have current to the coil pack? If you know there is no power at the coil keep tracing it back until you find where you do have power.
It sounds like maybe something is disconnected.
Old 06-18-2006, 07:56 AM
ned032002's Avatar
ned032002 ned032002 is offline
Or a Test light, one of my favorite tools, everyone should have one.
