Old 06-15-2006, 10:21 PM
redhoss's Avatar
redhoss redhoss is offline
Send a message via Yahoo to redhoss
Angry Trans or transfer case problems
I have a 88 s10 4x4 with a 2.8l and I have to pull that trans to fix the seal and when I put it all back on but It wont change gears it only goes up to second and if you try to put it in 4h or 4L it grinds it fills like it willn't lock in 2h. Does anyone have any idea of what it is is it the trans or transfer case? Thanks I really need to get this fixed.
Old 06-17-2006, 12:26 AM
Jimmy58's Avatar
Jimmy58 Jimmy58 is offline
Re: Trans or transfer case problems
Sounds to me that you have 2 seperate problems... when you pulled the tranny did you drain the tranny fluid or did you pull it with the fluid in it? the valve bodies of these trannys are real sensative about dirt. they will stick and not shift properly. I would pull the pan and clean it then put a new filter on and then fill with new fluid. Add about a cup of Marvel mystery oil and it willhelp clean the gunk out of the valve body.
The grinding going into 4H or 4 L sounds like you need to index your shifter and adjust the linkage. the procedure is outlined in most of the repair manuals.
Just my 2cents worth.Good luck and let us know what happens and what you find.
Nick
2003 S10 Chevy
99 GMC Jimmy
91 GMC Jimmy
88 Gmc Jimmy
1959 FLH Harley
1984 Honda Goldwing
Old 06-17-2006, 10:09 AM
redhoss's Avatar
I think I know what it is my TV cable needs adjusting
