Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-02-2002, 06:33 PM
eclipseiscummin eclipseiscummin is offline
speed
I need to know how to make a 96eclipse gst run 13.00's if you know how please reply
david
Old 08-03-2002, 12:59 AM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
First things first, go with:
Intake, that includes at least and cone type air filter, or you could go with a system that includes the intake pipe on our 2g's we also need to replace the upper intercooler pipe and BOV with new ones that flow better and do not leak under boost
Exhaust, at least cat-back, you will eventually need a downpipe, and high flow cat/test pipe
Boost controller, either manual or electronic, you need someway to turn up the boost
Fuel pump, either higher flow pump or rewire the stocker
Injectors, to make serious power the stock 450cc injectors wont cut it, for 13 second passes 550's will do fine
Fuel computer, you will need a way to control the new injectors the Apex-i S-AFC is a good unit
Bigger Turbo, for 13 seconds go with a 16g or bigger if you want to go faster in the future
to handle additional power, youll need an upgraded clutch
to tune, you will need a boost gauge and A/F or EGT gauge
Also, a turbo timer will help prolong the life of your new turbo
I may have missed one or two things, but this should pretty much cover you, depending on how hard you look for parts and if you are willing to buy used, you can do all of this relatively cheaply
-Peace
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 08-04-2002, 01:46 AM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
To make that much power on a FWD car, you will need a new intercooler. You will also need injectors and atleast an SAFC. Remember, the power it takes to make a FWD car run a 13 flat is the power needed to make an AWD run 12 flat.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
2000 sel hesitates/lurches on acceleration at speed 33hawkella Windstar 3 02-12-2011 01:33 AM
Can the four speed auto reach the same top speed as the five speed gearbox? ColeIketani Tiburon | Tuscani 46 01-29-2004 08:29 PM
speed speed speed speed smoke Off-Topic 6 01-03-2004 07:19 PM
Where and what was the speed limit when you reached your top speed. JE123 Street Racing 0 02-05-2002 04:39 PM
At what speed do you lose comfort when speeding? 2001 AE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 29 01-01-2002 07:25 AM
