Old 06-15-2006, 01:21 PM
Zyegon Zyegon is offline
95 Cherokee Stalling
95 Cherokee Sport 4.0L - It stalls cold or hot sometimes 3-4 times a day and other times it doesn't stall at all, It won't restart until I wiggle the coil. The 2 wire terminal plugin on one side is tight and clean, and on the other side is a new ignition wire going to the new cap and rotor. NEW COIL? or could this be something else? Why will it start just by touching the coil?
Old 06-15-2006, 01:23 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 95 Cherokee Stalling
Sounds like something is loose with the coil. YOu said it has a new wire? I'd check that wire to make sure it's tight and correctly attached.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-15-2006, 01:35 PM
I've checked and rechecked the wires to the coil, they are all tight and clean.
I can't figure out why the vehicle starts just by even pushing a finger on the coil itself, without touching any wires.
Old 06-15-2006, 01:43 PM
Very odd....I've heard of hard/no starting with a bad Crankshaft Position Sensor also.
So you just push on the coil and it starts, regardless of key position?
Old 06-15-2006, 02:11 PM
No, when it stalls,
I can crank it over, but it won't start.
I pop the hood, touch the coil, crank it over, It starts immediatley.
REAL STRANGE.
Old 06-15-2006, 02:22 PM
Something with the coil then, either the installation or you need a new one. There are some guys on here that could tell you what the voltage should be, but I'm not one of them.
Since it's 11 years old though, I'm thinking a new coil is in order.
Old 06-15-2006, 02:25 PM
Thanks
I'm guessing the same, but I was looking for a logical explaination to this rare problem.
Old 06-15-2006, 02:26 PM
Defies logic I guess.
Old 06-16-2006, 07:28 AM
89ltd 89ltd is offline
If the coil is lose, it may not be grounded until you touch it, try removing and cleaning the areas where it will ground when you bolt it back in.
Old 06-16-2006, 02:25 PM
So far, no problem yet. I didn't think about an external ground.
Thanks
