Go Back   Automotive Forums Car Chat > Engineering/ Technical > Small Engines ATVs Go Karts and Lawn Mowers etc
Small Engines ATVs Go Karts and Lawn Mowers etc From ATVs to Watercraft, Go karts to Lawn Mowers, discuss your small engines here.
Old 06-15-2006, 01:06 PM
drew300 drew300 is offline
too much oil
I haven't yet found an answer, so hopefully some-one has one....
I have an '87 Johnson 8 hp, 2 stroke.
It works fine if i leave it on the transom.
I store it for a week at a time, off the transom, laying down, handle up, which puts the spark plugs pointed down. To store it, I disconnect the fuel line, and let the carb run dry. When I remount it on the transom, it won't start because the plugs ar FULL of oil.
The ratio of gas / oil is right. I've checked the thermostat, it's good. (I figured if the engine was too cold, the oil would condense)
The repair people don't have any ideas, so I thought I'd ask here.
Thanks
Old 06-17-2006, 07:03 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: too much oil
You have an oil injection system in it, right? (It uses straight gas, no premix)
The injection system may be leaking. I am not sure if this is 'normal' or how to fix it.
However, everyone I know stores their outboards in a vertical position, (never lying down) by clamping it to a workbench, hanging it by the garage rafters, etc.
This may be obvious, but if it only has this problem, lying down, consider changing your storage position, if possible.
Old 06-19-2006, 08:11 AM
Re: too much oil
Thanks for the reply.
It doesn't have oil injection, just pre-mix the fuel. 50:1.
Since I don't get to use my boat too often, and I'm worried about thieft, and a couple of other things, I store the motor in the "trunk" of the boat, out of sight.
Yes, storing it upright is a good answer, but not the one I'm looking for.
This year I've bought "Amsoil" synthetic 2 stroke oil, which they claim I can mix at 100:1 and this will be fine for the engine, as well as pollute less.
I haven't had time to launch the boat yet, (!) so I don't know how this will work this year.
