Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 06-15-2006, 09:27 AM
Valgar Valgar is offline
Banned
Exclamation Starter on 93 Celica, help ASAPplease
Hello I am trying to work on the starter in my 93 Celica ST coup.
I see where the starter is located be hide the engine, under the intake manifold. From what I see there no easy way to get at it to remove and repair it. So I did a little poking around, I got under the car and saw that I also couldn’t access it from there either. As far as I can tell the only way to get at it is to remove the whole intake manifold, which for me work take a lot or work and likely more tools and know-how then I have.
I am hoping someone here knows an easier way to access the starter in a 93 Celica, or has a link for a how-to to remove it on a Celica. I have searched Google and haven’t found what I am looking for yet. Again I just need to know how to get at it and remove it.
Please help!
-Val
Old 06-15-2006, 02:01 PM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: Starter on 93 Celica, help ASAPplease
its easy, you need to have the car jacked up high, remove the clips from the starter, and remove the 3 (mabe its 2) bolts you can reach from under the car, theyll be a 4th that has to be removed from the top, then pull it off, i broke it loose from up above then got below and finished removing it
