Old 06-15-2006, 12:05 AM
e_quin77 e_quin77 is offline
1994 cavalier won't start
i have a 1994 cavalier with the 4 cylinder engine and recently it decided not to start. it was running just fine last time i drove it but the next day nothing. it tries to crank but just won't turn over and so i checked fuel pump, replaced fuel filter, checked battery, plugs, wires, starter and all is ok. i'm getting gas through the lines and to engine, but nothing. i don't know if this has anything to do with it but it has had bad lifters for a while and could that be causing a problem?? Also it was running hot but not all the way in the red for a while and i just recently replaced radiator with brand new one right before it quit running and it seemed like it was running too cool because temp guage would hardly move unless i set awhile at an idle. also it kinda backfired when i was trying to get it started but only once (timing chain perhaps) ?? if anyone has any advice i'd appreciate your input on the matter.
Old 09-28-2006, 09:19 PM
jhnsnjohn jhnsnjohn is offline
Send a message via Yahoo to jhnsnjohn
Re: 1994 cavalier won't start
try ecm, i have a 88 doing same thing
Old 09-28-2006, 09:32 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
I sure hope he got that fixed, after all it was 3 months ago
Old 09-28-2006, 09:36 PM
well i could see if he hasnt cause im going on 3 weeks and aint fixed mine yet..any ideas
Old 10-07-2006, 12:18 PM
Miipto Miipto is offline
Try your ignition module
Old 10-07-2006, 01:48 PM
well i found out that it was an injector i hope you got yours figured out
Old 10-11-2006, 07:29 PM
Wigtail Wigtail is offline
One bad injector stopped it from starting?
Old 10-12-2006, 04:26 PM
yes one bad injector can cause it. what happens is they all fire when they are supposed too but the one that is bad sends a signal to the ECM and shuts it down so that it wont fire the injectors after that, its BS but its a safety mechanism so that you wont burn the engine up
