Old 06-14-2006, 10:56 PM
RexT RexT is offline
Ok problem
I have a 96 blazer LT i just got used. Ok it ran good for the first two weeks and now when i start it up it shakes and shakes until im in second gear, and its jumpy in first gear it like jumps to shift and doesnt sound right it sound as its being overused or redlined but it isnt, please help me
thanks
Old 06-14-2006, 11:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Ok problem
thanks
First off, you should do a full tuneup.
Cap & Rotor
Plugs (AC Delco Platinum only)
plug Wires
Fuel Filter
Air filter
PCV valve
Full Bottle of Chevon Techron fuel injecter cleaner in a full tank of fuel (Cleaner in, and then fill up with gas.)
When the engine is misfiring, the tranny computer will get confused as well.
Also, is the check engine light on?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-14-2006, 11:06 PM
Re: Ok problem
yes check engine light is on, and everything should be good we got it from a dealer and it ran fine for awhile and one day just started doing it. but it sounds when i start it like its dieing like shakes and such then when i get into 2nd everything is fine
Old 06-14-2006, 11:10 PM
BlazerLT's Avatar
AF -Advisor
Re: Ok problem
Go to AutoZone and get the codes scanned. Get the actual code number, not the autozone monkey's interpretation of it.
The code will tell you what is happening and what is wrong.
And don't think that becuase it came from a dealer that it means that the things on my list above were changed.
Old 06-14-2006, 11:11 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Ok problem
Welcome to AF RexT
Trust me on this Dealers don't tune cars up unless they need it. Even then if it only needs 1 plug wire to run right some dealers will just replace the 1 wire.
You really can't balame them, they want to make as much as possible off every vehicle, and a tune up is something that you can negotiate in the purchase price as well.
That's what we did in the lot I was working in
Old 06-14-2006, 11:15 PM
Re: Ok problem
has anyone ever heard of this problem?
Old 06-14-2006, 11:17 PM
Banned
Re: Ok problem
That sort of problem is actually listed on this forum all the time, and a tune up cures it 90% of the time.
That's the wonderfull thing about computers, the codes tell you exactly what's wrong, and make troubleshooting easier than old school
Old 06-15-2006, 12:56 AM
BlazerLT's Avatar
AF -Advisor
Re: Ok problem
Yes, but you problem will be pointed out when you get your codes scanned for free at Autozone.
Get us the number and we will go from there.
Old 06-15-2006, 01:54 PM
Re: Ok problem
How much does it cost to go get this code done?
Old 06-15-2006, 02:18 PM
Re: Ok problem
sorry didnt see it was free*
Old 06-15-2006, 02:51 PM
Re: Ok problem
exactly what it sayes.
History DTC P0300
Random/Multiple
Cylinder
Misfire Detected
MIL REQUESTED
Since IGN NOT RUN
Since Clear P/F
Old 06-15-2006, 09:56 PM
BlazerLT's Avatar
AF -Advisor
Re: Ok problem
So you got a P0300?
Old 06-16-2006, 10:39 AM
billibong's Avatar
billibong billibong is offline
Re: Ok problem
Follow the advise that has been posted on this site. DO A TUNE UP!!
With the exception of the number three plug, everything can be done easily in a tune up, the whole job won't take more than two and a half hours, tops... and will cost about $150.
Random multiple misfires are usually caused by fouled or faulty plugs, bad rotor, or bad cap. By taking care of all of these at once it will give you less headaches in the long run.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 06-16-2006, 10:31 PM
BlazerLT's Avatar
AF -Advisor
Re: Ok problem
Cap & Rotor
Wires
AC Delco Platinum plugs ONLY!
PCV Valve
Air Filter
Fuel Filter
