Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-14-2006, 10:51 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Question Motor build....HELP!!!!
Hey all....
I have decided to dump my 7 bolt and go for the 6 bolt.
This is what I have figured out will be involved and what parts I would like to use...
Looking to be able to support a Garrett GT30R (so like 475-500hp)
Any input on this list would be appreciated!!!
Thanks again..
Engine Build:
PARTS
• Wiseco Pistons 8.5:1 85.5mm, eagle rods balance shaft eliminator kit
• Clevite engine bearings (rods and mains)
• ARP Headstuds
• Forced performance FP2 cams
• Supertech intake and exhaust valves standard size
• Supertech dual springs
• Supertech titanium retainers
• OEM front cover with oil pump
• OEM full engine gasket set
• Water pump
• Tubular exhaust manifold (fabricated)
• Full timing kit including hydraulic tensioner
• Cometic head gasket
• 1g CAS
• CAS conversion harness
• MAP sensor adaptor
• 10w30 engine oil
• synchromesh
• Oil filters
• Used 6 bolt engine
LABOR
• Port and Polish cylinder head, includes cleaning up of the bowels, de-shrouding exhaust valves, port matching intake and exhaust ports
• Fully assemble and blueprint engine
• Remove engine, disassemble, install engine with complete 6 bolt swap
MACHINE SHOP
• Oven bake and shot peen cylinder block
• Bore and hone with torque plate
• Align Hone block
• Balance complete rotating assembly
• Degrease Cylinder head
• 3 angle valve job
• deck cylinder head surface if needed
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 06-14-2006, 11:58 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Motor build....HELP!!!!
Just port your stocker exhaust mani instead of getting the tubular one and get a 5-angle vavle job instead. And why don't you just stroke the damn thing? It'll cost a little more but it will be much more worth it if you're running a GT30R. And don't forget about injectors and Link. Install new valve guides too.
95 Talon TSI AWD
97 Eclipse GST
Old 06-15-2006, 12:13 AM
mtcs's Avatar
I already have the tubular manifold....
What is the difference between a 3 and 5 angle job?
Im going to stroke it later...kinda ran out of cash for now
I have 850cc injectors and DSMlink
1996 ECLIPSE GST
Old 06-15-2006, 12:19 AM
5-angle vavle job just has two more steps to it so that the air flows better. You probably don't *need* to do a 5 angle, but every little bit helps
95 Talon TSI AWD
97 Eclipse GST
Old 06-15-2006, 01:50 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Why the hell would you go through building it 2.0 if you are just going to stroke later? That makes no sense, just save and extra $400 for a crank and you'll be set. I say forget the 5 angle, 3 is good enough. Also, I would go OEM MLS head gasket over the cometic. Cometics need a pretty fine finish to seal right, OEM MLS ones just go on like a composite, no special surfaces needed. Are 850s going to be big enough for a GT30R?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-15-2006, 03:04 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Yeah since you are going to rebuild it anyway, you might as well stroke it now. On the pistons and what not the cost will be the same as well as the machine shop costs. The only thing that will be different is you need a new crank. And you can get a 2.4 crank cheap!
Also make sure you get the balance shaft removal done.
1991 GSX 2.3 Stroker
Old 06-15-2006, 07:15 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Sigh...just like I didn't really need a fully built drag motor either. All the money I blew on this thing I could have gotten DSMLink, a TRE tranny, and a/f upgrades. "Oh yeah Craig, I'll take the Stage IV 6-bolt head, and oh yeah, how about springs and retainers so I can redline at 10,000 RPM, and oh sure why don't you throw in xxxx....etc." And here I am, driving 5 miles under the speed limit every day. The D$M gods frown from above. lol.
I'm mucho stupido, learno from mistako.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 06-15-2006, 08:22 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
fuck slowboy
now - 2000 civic
soon - 2002 is300
Old 06-15-2006, 09:58 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I'm sure I'll be saying the same thing when I'm all done with mine. lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 06-15-2006, 01:50 PM
SySt3mR00t SySt3mR00t is offline
Send a message via AIM to SySt3mR00t
I do not agree with the head gasket ... i would go cometic .. if you are getting your head decked .. than definitly go with cometic. If you are already rebuilding ... GO STROKER! It was the best thing I have ever done to my car... esspecialy if you want to support that turbo. As for valve job 3 angle should work fine. My head is currently getting a 3 angle.
96 GST
Old 06-15-2006, 01:51 PM
MexRocket's Avatar
MexRocket MexRocket is offline
slowboy does suck nuts...
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 06-15-2006, 02:25 PM
mtcs's Avatar
Looks like you guys are right...im going to stroke that 6 bolt also....I mean, might aswell while I have the motor appart.
Anything else I can do for improved performance while the motor is appart....besides overboring etc...
Thanks
1996 ECLIPSE GST
Old 06-15-2006, 04:36 PM
E-Klips E-Klips is offline
Banned
You dont need a 5 angle valve job... Shit you dont even need to upgrade the stock 1g head besides cams. If all you want is 500whp, build a bottom end, put a stock head on it, go with a GT35r or FP3065 with the money you saved and get an intake manifold. Port the stock exhaust manifold out, add dsmlink and a set of 950cc injectors and your good to go...
Screw a stroker kit. Yes they spool large turbos quickly but a GT35r is no where close to large. I spool my GT42r just fine with my 2.0l and that is substantually larger than a 35r. Is it really worth the extra money and hassle of finding everything and getting it to work correctly (special pistons) and the added cost at the machine shop for line honing for the 4g64 crank? I just dont understand why everyone thinks a stroker kit is the way to go these days. Oh well.
Old 06-15-2006, 05:59 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
A gt30 is a bit small for a storker
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-15-2006, 11:17 PM
mtcs's Avatar
I already know for my power goals I dont need the stroker. But why not put the stroker in it now so later on when I upgrade my Turbo for a bigger one, I wont have to go back and tear my motor appart. Plus my motor is in pieces now, so doesnt this seem like a good time to put the stroker in? instead of killing myself later tearing the 6 bolt appart to put the stroker in.
1996 ECLIPSE GST
