Old 06-14-2006, 08:03 PM
MORROW5 MORROW5 is offline
Thumbs down 97 Taurus (turns Over) Slow At Times
Yo,
I Got A 97 Taurus 6 Cyl. The Other Day It Started To Crank Alittle Slow And Then Started. Two Days Later It Is Still Doing The Same Thing I Just Repaled The Battery Cuase It Was 5 Years Old And I Thought It Was Time To Replace It To Be Safe. It Is Still Doing The Same Thing When I Go To Start It Cold Or Hot It Just Cranks A Little Slow And Then Starts Kind Of Like A Low Battery Or Diry Cable But Its Not That. It's My Only Means Of Transportation And I Really Need To Fix This Fast Please Help If You Can. Thanks !
Old 06-14-2006, 08:51 PM
brokenantimatter brokenantimatter is offline
Re: 97 Taurus (turns Over) Slow At Times
Heavy Battery Drain or Faulty Battery
Faulty Starter Motor
Faulty Fuel Delivery System
Old 06-14-2006, 09:37 PM
THANKS
REPLACING THE BATTERY DIDN'T HELP AT ALL SO I FIG. IT'S THE STARTER I CHECKED ALL THE TERMINALS AT BOTH ENDS EVERYTHING WAS GOOD.
I MIGHT TRY SOME OCTANG BOOST OR SOMETHING LIKE THAT AND SEE IF THAT MIGHT HELP IT. IT CRANKS AND STARTS BUT IT JUST CRANKS SLOW LIKE IT'S MISSING SOMETHING AND THEN BAM IT STARTS.
Old 06-15-2006, 02:27 AM
KimMG KimMG is offline
AF - Advisor
Doesn't sound like a fuel problem since it does start. Turning over slowly maybe caused by worn bushings (bearings) that are binding in the starter motor.
Old 06-15-2006, 05:13 AM
Millermagic Millermagic is offline
Before replacing anything else, I'd get new battery cables.
Do you have anyone that is able to help you? Get a volt meter and set it for DC and put it on the battery and have someone try to start the car and see what it does. If the voltage drops alot and it is a new battery it probably is the starter motor. If the voltage does not drop at all, there's a problem getting the juice to the starter.
