Old 06-14-2006, 07:00 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Need help now with O-rings
I've got the LIM back on and ready for the UIM. There was 2 orange O-rings about the size of a nickel and a black one quarter sized in the box with the LIM. Not sure what they are for? I"m kinda concerned about where they go. In putting the pcv back in seems like I remember something about two black O-rings. There was only one in the pack with the larger orange one and a spring. The old UIM did not have a spring and only 1 O-ring on the pcv.
Now in regards to the injector O-rings, do the injector pull out of the fuel rail? I'm assuming they do and one set of rings go up top and the other set on the bottom. I have pulled gently but can't remove an injector from the rail.
Thanks
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 06-14-2006, 07:56 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Need help now with O-rings
Thanks
See link below for PCV valve guide. Only one small black o-ring goes on the PCV valve. The big orange o-ring seals the UIM opening for the PCV valve and MAP sensor retainer. The spring is for the MAP sensor retainer that locks down over the PCV valve.
Do you think the other o-rings are for the 90 degree plastic elbow. Did the new elbow come with o-rings? The kits have o-rings for the elbow anticipating it will be OK and re-used.
http://macgp.clubgp.com/howto/engine/pcv/gt/pcv.html
On the fuel injectors, yes they will pull off the rail. Pull harder. You will have upper and lower fuel injector o-rings. Make sure they match.
BTW - The u shaped retainer/clip to each fuel injector at the rail must be removed first before pulling each out.
Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 06-14-2006, 08:38 PM
wlkjr's Avatar
Bob, the sheet with the pcv says to use two black o-rings under the pcv. I'm sure one of the orange goes under the elbow on the side of the UIM. That leaves one orange and a black one a little larger.
I"m installing the throttle body now, after a restroom break. I must like these late hours. Especially since the Braves stink.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-14-2006, 08:48 PM
BNaylor's Avatar
Using two o-rings won't hurt but I have only seen one ever used and it works OK. Lets say I never get any EGR flow problems due to a missing o-ring.
Hang in there sounds like you are progressing quite well. I forget you are two hours ahead of me. The Falcons weren't much better but there is always the next season. Good luck!
Timeslip 08/12/06
Old 06-14-2006, 09:56 PM
wlkjr's Avatar
There were two packs of injector O-rings with six in each one. Six were fat ones and six were a little slimmer. I replaced the six upper with the fat ones and the skinny ones don't fit the bottom. I think both should be the same size.
Go Braves-----and take the Falcons with you.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-14-2006, 10:28 PM
BNaylor's Avatar
I could have sworn that they were all the same size. See pic below:
We'll take them. We could use the Falcons since we don't have a Pro football team. Anything is better than nothing. I don't care for Arena Football.
Timeslip 08/12/06
Old 06-14-2006, 10:52 PM
wlkjr's Avatar
After I learn to fix my GP, I hope I can figure out how to post pics like that. I guess I'll have to get six new o-rings tomorrow for the bottoms. Then I'll be down the homestretch.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 06:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Wally, I think that other o-ring is for the small elbow out of the back of the UIM where the brake booster hooks up, I'll check at work when I get there.
Quote from Bob "We'll take them. We could use the Falcons since we don't have a Pro football team. Anything is better than nothing. I don't care for Arena Football."
You want the Lions Bob? I'm sure no one in Michigan would care. At least the Tigers have finally done something. The Pistons choked in the playoffs (but still had a great season) and my beloved Red Wings choked in the first round (like they always do when they win the Presidents Cup). Much of that was thanks to the refs not calling the obstruction like they said they would (and the rest was Dwayne Rolosons awesome goaltending).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-15-2006, 06:13 AM
wlkjr's Avatar
Smile Re: Need help now with O-rings
I thought Red Wings was a brand of shoes.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 06:23 AM
BNaylor's Avatar
No problems on pics we can help you there too.
My question is how did you wind up with improper o-rings?
Fuel injector that is.
Timeslip 08/12/06
Old 06-15-2006, 06:26 AM
wlkjr's Avatar
I'll have to consult my parts guy about how I ended up with improper o-rings.
Hey Rich, how did that happen? LOL
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 11:58 AM
richtazz's Avatar
I will call Dorman on this issue. I pulled another intake kit off the shelf, and it has 2 different size o-rings as well, so it has to be a problem at the manufacturer. I pulled the GM o-ring kit, and all the injector o-rings are the same size.
Old 06-15-2006, 12:06 PM
wlkjr's Avatar
I picked up some at Advance for $3.98 for four, naturally I had to buy two sets. I should have just left the uppers in as they were extremely hard to remove and they all looked in new condition. At least they weren't $8.00 a piece like the heater o-rings.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 12:37 PM
BNaylor's Avatar
Yeah Rich, we know. We figured that out last night...lol
The pic is of the proper fuel injector o-rings AC Delco PN: 217-454.
That is why I stay with genuine GM/AC Delco only. As a matter of fact the L36 and L67 injector seals are identical and I have a pack in my spares kit.
I'll put Dorman parts on my sh*t list.
Timeslip 08/12/06
Old 06-15-2006, 12:50 PM
richtazz's Avatar
I'm still waiting for a call back. We've sold a bunch of these, and haven't had a problem yet (I personally have installed three of these intakes and the ones I used had the correct o-rings in the kit). I think someone oopsed at the factory and put the wrong parts in the bag. I'll keep you posted as to what I find out.
Bob, don't write them on your list in ink, just in case they come up with a solution, or realize their oops.
