Old 06-14-2006, 03:54 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
1997 SE Steering Wheel
The steering wheel on my 1997 SE always seems to be turned to the left when the wheels are straight. This causes a small problem when driving. Feels like I am fighting the steering wheel. I had an alignment done about 6 months ago and that did not fix the problem.
Old 06-14-2006, 04:19 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1997 SE Steering Wheel
Have you tried rotating the tires, front to back, back to front and then see what it does. I did not believe it but I helped a fellow local GTP owner out last month. He spent a lot of money on front end stuff and wheel alignment. What we found out is one of his nice V rated tires developed what is called radial pull which was causing a pull to the right. Since the tires were replaced it tracks straight. Just an inexpensive suggestion but worth trying.
Timeslip 08/12/06
AF Community Guidelines
Old 06-14-2006, 04:34 PM
I have my tires rotated on a regular basis. Seems like this is the case no matter how many times I have them rotated. Can you describe what radial pull it please?
Old 06-14-2006, 04:51 PM
BNaylor's Avatar
It is a phenomenom with radial tires and simply one possible problem out of several if the alignment is good. See link below for description and possible corrective action.
http://www.tirerack.com/tires/tirete....jsp?techid=12
Timeslip 08/12/06
