| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
03 GT question
hi all, well my question is im going to buy a 03 mustang and i want to supercharge it but as i serch around and look at the different one's they all include new injecter and fuel pump. keeping in mind this is gonna be a daily driver how much will that affect my mpg and are there one's out there where a change in the fuel injection isnt needed??? if any of you have SC your gt let me know how its going and any info i would appreciate... thank you
Re: 03 GT question
Yes you have to upgrade your fuel system but most kits will come with it.
This is the most popular supercharger system on the market for the price. http://www.dallasmustang.com/page/pr...=&product=2690 http://www.allfordmustangs.com/reviewpost/showproduct.php/product/19/cat/3 It will come with everything you need. |
Re: 03 GT question
how much will that affect the mpg from the 24-18 that they get..... how's the feed back on those SC... ebay has a SC from saleen priced at 4,199 have you heard anything about that one.. cuz its around the same price and i guess should put out 405 hp and 425 lbs..... thank you
Re: 03 GT question
With the vortech kit
On a automatic your looking at maybe 3-4mpg drop in city and 2-3 drop in highway. On a manual 2-3mpg drop in city and a 1-2mpg drop in highway. You could always off set this by going with a different set of tires. Saleen Parts are built to a different standard than your GT you would have to do serious work to you engine to keep up with strain it would add. As far as gas mileage it will most likely hurt it and before anybody comes in here and starts fucking arguing with that. Cars that come factory with Turbos and Superchargers in order to gain mpg increases, they are built to specification to work with that supercharger or turbocharger. They make forced induction systems you can add to your car to get increased mpg but most of the time their hp boosts aren't worth it. |
Re: 03 GT question
thanks for the info, another question is would i need to run 91 oct or could i get away with run 89 or 87. or is that not a smart thing to do??? thanks again...
Re: 03 GT question
If you are that worried about gas costs do not install a supercharger sell your mustang and get yourself a Honda.
As far as your answer goes most likely you will need to increase your octane rating to premium. Determining factors: Current Compression Ratio Current Fuel Injector /lb pressure Current Fuel Pump GPH delivery Current Detonation Timing Then compare Supercharger CFM Supercharger PSI Supercharged Fuel Injector /lb pressure Supercharged Fuel Pump GPH delivery Supercharged Detonation Timing |
Re: 03 GT question
and yes, your MPG will drop, its the price you pay for more power. also, you will have to run premium octane if you dont already
07 jeep cherokee srt8 99 saleen s281 05 cbr 1000rr |
Re: 03 GT question
ok, so all and all which would you advise i get??? they're both around the same cost and if the saleen SC last longer on average, it sounds like i would be better off going with the saleen and to be honest i am strongly looking into turning the GT into a saleen clone, body and hp wise.but i still would like to get your guys opinions.... will both fit under the stock hood??? and will the stock tranny hold up to 425ft-lbs or will that need to be upgraded
Re: 03 GT question
depends, i know someone with a vortech centrifical, and 4.10s, and they still get better milage then my stock 6
2004 F350 6.0 4x4 auto SRW SCT X3 with innovative tunes, autometer boost/trans/pyro, AFE stage 2, MBRP 4" no muffler or cat, EGR delete, ARP studs, 8' fisher MM2, misc appearance 90 F350 7.3 IDI 4x4 SRW (sold) bolt on 02 mustang 232 4R70W vert (sold) built 88 toyota pickup (sold) bolt on 92 camaro LO3 TBI (sold) |
Re: 03 GT question
the saleen SC could produce up to 425 ft-lbs torque. will the TR3650 tranny hold up to that or will i have to do a tranny swap??and will those SC fit under the stock hood?? thank you all
Re: 03 GT question
it might, depends on how it was driven, i know people with over 400 HP and are fine with them, but my buddies mach 1 has 12000 miles on it, stock, and every time he takes off he spins straight through second and chirps third, the third gear synchro is gone, there is actually a tsb out for them, if you could afford it, i would have a T-56 put in
Re: 03 GT question
the saleen cars do not come with upgraded drivetrain except for a rear end [as an option] so yes you will be fine. i would advise the saleen blower.
saleen clone on the other hand i am not a fan of, unless you are leaving off the saleen stickers stripes and banner
Re: 03 GT question
I have an 02 GT convertible. ATI ProCharger with 10 lb pulley gave me 405 HP at the wheels. I lost 1-2 mpg overall, but it really depends on how you drive. My mileage runs 14-15 in town and up to 22+ on the highway.
Before the SC I was WOT most of the time Now, it's a lot more serious and I find I'm not WOT much at all (depending upon who is in the lane next to me). That probably affects the minor difference in mpg.You have to go with the bigger (42 lb) injectors (I had to buy them in addition to the HO ProCharger kit) and a good fuel pump (255 LPH included in the kit). It's very important that you manage fuel flow and air/fuel ratio, and the pump and injectors contribute to it. In addition, the tune (chip was included in the kit) and MAF range need to be coordinated. The bottom line is that I had a good, reliable, quick little cruiser (14.8 1/4 mile at mile-high altitude), and after $5,000 I have a very quick car that is often in the shop (gauges, tuning, pulley changes, SC oil changes, fuel pump failure, trying to dial in the AFR etc.). I've had times I've had to walk home or nurse the car back to the shop. It's been 3 months now and it's starting to settle down. I don't know how fast it is because (assuming it will go faster than 13.5) convertibles need a roll bar to meet safety rules. Would I do it again? ABSOLUTELY!! Although this is not my only car. If it was my only car I might not. |
