Old 06-14-2006, 02:12 PM
jpfergu jpfergu is offline
No spark
Ok, I've narrowed down the problem on the "starting challenged" 88 civic. It isn't the fuel system. I'm not getting a spark at the plugs. Is it most likely:
A) Distributor cap
B) Distributor rotor
C) Ignition coil
D) Ignition control module
E) None of the above
The guy at Autozone said it probably was the control module, not the coil. Any ideas???
-J
P.s. I put in new plugs already
Old 06-14-2006, 02:17 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: No spark
A) Distributor cap
C) Ignition coil
-J
replace the cap/rotor anyway, and if that doesn't fix the problem, get a coil from any other 88-91 civic/crx or 90-93 integra. Other years may work too. If the coil doesn't fix the problem, replace your distributor, because it's probably the ignitor.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-14-2006, 09:27 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: No spark
The Honda dealership replaces your ignitor for free since it was a recall for all 4th gen civics. Might wanna take advantage of that since and see if it takes care of your problem.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 06-17-2006, 04:36 AM
KrisSmithRocks's Avatar
KrisSmithRocks KrisSmithRocks is offline
Send a message via AIM to KrisSmithRocks
Re: No spark
Does the problem happen most in hot weather? cause if it does it's the main PGM-FI relay located next to fuse box under the dash, they have weak solder joints in our gen cars and when it gets hot Ingintion signal cuts out.
89 Honda Accord LXi 2dr- Daily driver SOLD (sniff sniff)
89 ED CRV... soon to come GSR head, ARP studs top and bottom, T3/T4 at about 6psi ... it's quick...
89 ED DOHC ZC
