Old 06-14-2006, 01:55 PM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
Duplicolor Question
i was wondering...how does duplicolor compare to tamyia ts paints? also is tamiy primer compatible with duplicolor, and is duplicolor clear just as good as ts 13? im asking because i am painting a supra right now, which is primed with tamiya white primer, i plan on using duplicolor super red 2, and clear coating with duplicolor clear or possibly ts 13, which should i use?
Old 06-14-2006, 03:39 PM
wouter1981 wouter1981 is offline
Re: Duplicolor Question
In my humble experience: don't mix.
I've had really bad results when spraying different marks. I once tested some MOTIP clear over tamiya metalic red and it was OK. Then i did MOTIP clear over tamiya aluminium and the clear dissolved the paint and etched trough the primer into the plastic. Took me so long to clean that up. Use same type of primer, paint and clear and you'll be save. The tamiya pirmer should be good for the duplicolour.. but i would bet my head on it.
What i have experienced is that marks like MOTIP and DUPLICOLOUR are slightly inferiour to tamiya, but MUCH cheaper. And if you take you're time with polishing the duplicolour, you'll have a startling paintjob. Just.. use the same brand for paint and clear... you won't regret it.
Old 06-14-2006, 03:59 PM
Some_Kid's Avatar
thx man
Old 06-14-2006, 04:21 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
in my personaly experience they both work fine together as long as you don't spray heavy wet coats (VERY heavy coats)
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
