Old 06-14-2006, 11:03 AM
moonunit moonunit is offline
Exclamation How to disconnect ABS system??
My ABS has been going off whenever the brakes are pressed more than once when stopping. Can someone direct me on how to disconnect the ABS unit??
Also:
My gas gauge is not reading properly. what do i need to do to fix it??
thanks in advance!!!!!
Old 06-14-2006, 11:09 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: How to disconnect ABS system??
First of all this was asked a while ago, and I'll give the same answer - BAD IDEA, its there for a reason, get it fixed. Second if its a '95 and up, you cannot disconnect the system, as its controlled by the PCM, which controls everything else on the truck, you can't disconnect it.
Old 06-14-2006, 11:24 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I agree, bad idea, get what is causing the problem fixed and you will have a much safer truck. he has a 98 so it is controlled by the PCM. You have a bad sending unit which has caused your gas gauge to most likely malfunction which needs to be replaced and it sits on top of the fuel pump inside the gas tank I believe. Good luck
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 06-14-2006, 05:30 PM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
I got drilled for that last time so im not sure if I wanna tell you how to unplug the ABS if you have a first gen blazer......
Bad sending unit most likely thats the problem with my blazer as well
edit: nm just saw that it was a second gen blazer
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
