A/C not working on 92 Lincoln Cont.
I have put alot of work in this car and would like to keep it on the road. The A/C is not working and if I can fix it I will continue to drive it. I have had a very good retired mechanic work on it and diagnosed it as the integrated control module. I purchased a new ICM but the A\c is still not working. The freon level is correct and we have bypass the low freon switch to make sure that is not the issue.
I enjoy driving this car but with summer here I need the A/C or will need to look for another car. I hate to do that. Have switched out the air ride and have less then 8 months on a new head gasket replacement. |
Re: A/C not working on 92 Lincoln Cont.
Why would you care about the ICM?
Are you sure that its not something wrong with the A/C itself? |
I just went through a similar problem with my '90. It ended up being the AC clutch. The clutch was too weak to fully engage the compressor. After repair, it blows snow balls
try refilling the a/c system. I have an 80 Lincoln Mark VI and propane did the trick and isn't only blowing snow balls but I'm pretty sure it's changing atmospheric temperatures outside the car!
P.S.: Don't listen to anyone about the use of propane in an A/C system. I also filled up my grandma's 94 F-250 Ext Cab Long Box lowrider (it has factory runningboards that make it look lowered) and her A/C works like the day she bought it. My car hasn't blown up, neither has hers, and it likely never will. |
Did you ever find a fix. My Air just went out and I took it to get it repaired and they told me it was an electrical issue, that the fuse was not being sent any juice. I am trying to troubleshoot now. ANyone got any Ideas?
