Old 06-13-2006, 09:48 PM
glassman48 glassman48 is offline
99 V6 code help
Can anybody tell me what the code 0340 camshaft position sensor A Bank 1 circuit malfunction means? And also the tac has quit working any help would be appreciated.
Old 06-14-2006, 07:05 AM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Re: 99 V6 code help
I would buy a new sensor, replace the current one and then disconnect the battery for a couple of minutes so clear the codes. I don’t know as far as the tac goes.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 06-14-2006, 07:39 AM
Re: 99 V6 code help
Kevin, Thanks for the answer. I quess I should of posted what I have already done . The prob. with the truck is it missfires on hard excel. I have replaced Camshaft sensor, Crank shaft pos.sen, Vehc.speed sen, Mass airflo sen, plugs, plug wires, distributer cap, and rotor. Disconnected the batt. every time and the code 0340 camshaft pos.sen. A. Bank 1 circuit mal. comes up. I have the Actron OBD2 super scanner. The tac started by jumping all over and then quit compleatly. Any other suggestions? Thanks, Dan
Old 06-14-2006, 10:41 AM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: 99 V6 code help
You need to get it on a real scanner that will read cam synch signals, the dist may be off slightly creating a mis alignment of the rotor to the cap, the signal reads in degrees plus or minus, degerees close to 0 is the best, you must rev the engine over 1k to get this reading, not sure if the Actron reads this.
