Old 06-13-2006, 09:43 PM
jagplates jagplates is offline
98 4cyl failed smog test
My 98 Voyager, with 154,000 failed smog with high NOX and borderline high CO, HC was OK. High NOX points to lean mixture but high CO points to rich mixture. Timing is not adjustable. Any ideas?
Old 06-19-2006, 12:36 AM
meezy09 meezy09 is offline
Send a message via AIM to meezy09
Re: 98 4cyl failed smog test
if timing isnt adjustable and egr operation is fine, and o2 sensors are working how they should (not lazy etc) then its gonna need a cat.
Old 07-01-2006, 08:16 PM
meezy09 is correct. The California spec car does not even have EGR (although the alldata manual says it does). I replaced the catalytic converter, and emissions dropped to near zero. The car passed smog with score like a new car.
Too bad that there are no aftermarket catalytic converers for California cars. The cat cost me $612.
Old 07-03-2006, 11:46 PM
AwPhuch AwPhuch is offline
Banned
I read you can put 2oz of acetone per 10gallons of gas in your tank
The acetone is diluted to non-dangerous to plastic/rubber components, but it does allow the fuel to atomize better and burn much much cleaner (as close to a perfect fuel as propane)
http://peswiki.com/index.php/Directo..._Fuel_Additive
http://pesn.com/2005/03/17/6900069_Acetone/
I would recommend doing your own research..I have been running this mixture in my 1992 Dodge Dakota with absolutely no bad side affects...truck idles and runs smoother
Brian
AwPhuch
