| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
new parts hook up
I went out and bought a manule boost controller and a boost gauge for my 91 tsi, does any body know how to hook them up?? and where is the best place to run the vaccume line from the engine to the inside of the car? thanks
Re: new parts hook up
T the line coming from your blow off valve and stick the one end of the boost controller (inlet) to that side and then stick the outlet to your waste gate actuator. As for your boost gauge also T it from that line and run it through your steering column (You might have to drill a small hole)
If you need a pic Ill show you.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
That's a terrible way to route the lines. I had it like that and had awful boost creep / spike and a malfunctioning BOV. I can't stress this enough, the BOV and the MBC need their own lines!! Do not share these lines, you can tap the boost gauge onto the BOV line only. Since you are a 1g, you should have a boost source right on your j-pipe, use that for your boost controller. Use the line going to your BOV for the boost gauge. ONLY route them this way, it will save you a major headache later (believe me I've had it)
steviek, if that's how you have your lines hooked up, change it to how I said above, get a boost source tapped to either the licp or the j-pipe. Make that MBC line as short as possible. The difference is huge!
now - 2000 civic soon - 2002 is300
yea thats how I have it on mine... But i just followed a diagram for like joe p boost controller.
It seems to be working for me I don't know if I should mess with something thats not broken? What kind of difference are we talking about?
well there's been some lengthy discussions about it on tuners, but basically the mbc causes the BOV to get an innacurate signal, it opens too late. When they share the same line, they "trick" eacother, read about it on tuners if you really want more info.
Another HUGE aspect is the amount of vacuum line. For a MBC, you want the absolute shortest vac line possible to reduce boost spike. I had my JoeP T'd off from the BOV just like recommended, but look how far that is from the wastegate. Mine was around 4-5 feet of tubing. By tapping the MBC to a boost source much closer to the wastegate, you decrease the amount of time it takes for the air signal to get to the wastegate, therefore you reduce boost spike. I used to spike to around 21 psi, then settle to around 16-17. This is why it was so hard to dyno tune, and my numbers weren't that impressive. With the new mbc tap, i have about 6 inches total of vacuum line, and ZERO boost spike. Holds 20 psi from 3200rpm to redline. Really do yourself a favor and look into it, you'll notice the differences immediately.
Yea I get what your saying, makes sense. Now I actually got to go out there and do it BORRING>... Oh well. Thanks for tapping (no pun intended) into my happy sheltered world.
ok so which pipe is my J pipe there are so many pipes in one area. is it the one with the blov on it that is hooked up to the intercooler as well?
The J pipe is the intercooler pipe that looks like J...hence the name.
unless he is still stock. 1g's don't have a jpipe, it's more of an L pipe than anything. Its the pipe coming out of your turbo, NOT on the intake side, the other one, it's black. Someone with a 1g explain it better!
You'll notice the difference. I had a local shop weld the source for like 20 bucks too, it's very easy in labor.
so im looking at the bov and the vaccume line that is hooked up to it going back in to the intake manifiold, that is what i hook my boost gauge up to?
ok so i now have every thing hooked up the way it should be: the gauge to the bov and the controller to the J pipe, i am running what looks to be about 10psi. (I need more boost!!) i don't think my controller is turned up for more boost, now my question this time is what is the safe amount of boost that can go through the engine for the stock 4g63 engine with only upgraded tubuler manifold, 16g small turbo made for a 5 speed (all from DSM parts.com) but installed on an automatic for now, with cat back exhaust, opened up k&N airfilter intake, high pro fuel pump and stock intercooler.
as much as you want until you heatsoak that intercooler, but only if you have upgraded your injectors, otherwise ~12 psi. Get at least some 550s. But then you'll need a logging device (good idea anyways) and a tuning device.
