Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 06-13-2006, 08:40 PM
jaybb101 jaybb101 is offline
Parking Brake Problems
I am having problems with my parking brake. When the parking break is pushed down, the parking brake will not hold on a hill. When i release the brake then i have to pull the lever up with my hand to get the lever to come all the way up to its original position. I have check the bolt to tighten it and it is all the way up and is as tight as it can be. I am thinking that there is a spring missing that is not pulling the lever back up. I think that there is a spring to launch the parking brake lever back up, and it is gone. It may be the parking brake cable is stretch or the brake pads in the back are gone. I would guess that it would be one of those three things.(spring gone,cable stretched, or bad brake pads)
I would like some advice on what may be the cause of my parking break not working and not springing back up when realsing it.
Thanks.
Old 06-17-2006, 10:39 AM
k5dan's Avatar
k5dan k5dan is offline
Send a message via Yahoo to k5dan
Re: Parking Brake Problems
I just delt with that problem on my 89, most likely like mine both of your parking brake cables are froze, i bought both from autozone for 13.99 each but that was with a shop discount. they are both the exact same part no and arent too hard to replace but if the are froze might as well be ready to replace your shoes as they will most likely be prematurly worn out.
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
Old 06-17-2006, 12:17 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
ya i got the same problom on my 95 dodge dakota
Crop circles are Chuck Norris way of telling the world that sometimes corn needs to lie the fuck down
The Great Wall of China was originally created to keep Chuck Norris out It failed miserably
A Handicapped parking sign does not signify that this spot is for handicapped people. It is actually in fact a warning that the spot belongs to Chuck Norris and that you will be handicapped if you park there
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris
