Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 06-13-2006, 07:53 PM
TNRabbit TNRabbit is offline
Thumbs down A/C Idle Up Not Working
I have a 2000 Honda Civic EX VTEC Sedan. When the A/C compressor kicks in at idle, the engine idles down and labors/shudders. Isn't there a compressor idle up valve and where is it located? How do you adjust this??
TNRabbit
Old 06-14-2006, 12:43 AM
Shinobi_jak Shinobi_jak is offline
Send a message via Yahoo to Shinobi_jak
Re: A/C Idle Up Not Working
I think I have the same problem, do you also get really low acceleration with the A/C on? Every now and then when running, it will pull alittle, is that normal?
Old 06-14-2006, 06:22 AM
Read the post again; this happens at idle in Park or Neutral. On my Toyota pickup there is an idle up valve to idle the engine up to 1100 rpms when the compressor kicks in...I was just wondering where this adjustment is on the Civic...
TNRabbit
Old 06-14-2006, 02:40 PM
Oh, I C... I have the answer... that idle adjustment is right around where the intake goes. its the one that is facing the same direction as where the intake goes. I hope that helps, I haven't taken a picture.
Old 06-20-2006, 01:45 AM
sirciv sirciv is offline
i have the same problem too, still not working
Old 06-20-2006, 03:29 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
This is actually normal. The A/C uses a lot of power from the engine in order for it to run.
