Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 06-13-2006, 07:44 PM
catprotector catprotector is offline
Changing Bulbs
It was pointed out to me today that my left tail light is out. I suspect I may have to change the bulb and was wondering how to do it. Do I need to pop the trunk and then unscrew something or is there a way to pop the cover off the tail light and change it? How long do the tail lights actually last? I figure I'll get it changed soon but was hoping it'd be easy.
Old 06-13-2006, 08:24 PM
jsgold jsgold is offline
Re: Changing Bulbs
The tail light bulbs are easily removed. On Berettas you need to pop the trunk open and remove the tailight assy. by removing three wingnuts (sometimes 4) and then pulling the lense assy out just enough to see the sockets/wiring. Then you twist the socket(s) and pull them off. The bulbs are removed by pushing in on them and twisting. They should pop out. Bulbs should have two little metal tips on them, on side is slightly higher than other. the socket has slots with slightly longer one and a shorter one. You must put the bulb in so that the pins match up with the slots. Push in and twist to lock. re-assemble. Be sure you get the same bulb, specify which bulb is bad when buying, example turn signal bulb, brake light bulb etc.
see if this helps
http://www.autozone.com/servlet/UiBr...3d80148784.jsp
I used to be indecisive, now I am not so sure.
Old 06-13-2006, 11:26 PM
Re: Changing Bulbs
see if this helps
Thanks for the info. It doesn't sound too difficult.
Old 06-17-2006, 10:41 AM
Re: Changing Bulbs
BTW, do you happen to know what model of bulb it is for the Beretta's tail light? I went to Walmart yesterday and they had different ones for sale.
Old 06-18-2006, 10:15 PM
Re: Changing Bulbs
Without more information, year etc. no I cannot be sure. Here is a link to Advance auto site that is very handy. You can also use the link I put on here earlier from autozone. Just click on year, type of car, etc and you can easily look them up.
http://www.partsamerica.com/VehicleS...e=default.aspx
Old 06-20-2006, 01:42 AM
Re: Changing Bulbs
I have a 1995 Beretta.
Old 06-20-2006, 09:50 PM
Re: Changing Bulbs
Looks like a 2057LL will work for both sockets in rear. Suggest you replace them all so they are all fresh and new, or at least pick up a couple of spares.
Old 07-06-2006, 01:38 AM
Re: Changing Bulbs
Thanks. I was able to change the bulbs without too many problems.
