could it be? a 383? for me? maybe..
how much hp does a 383 lt1 put out? How much does it ususally cost do get the 350 to a 383? and are there any specific lt1 years that are better for a 383 than other?
![]() car audio guru...
Re: could it be? a 383? for me? maybe..
not sure about the lt1 part but a new crate GM 383 engine with carb. and dual plane intake and no mods cranks out 425hp stock
o. i thought you just make the cylinders bigger to make it a 383
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
Seatbelts Saved My Life
I know summit racing sells '383 stroker' kits. They are priced around $2,500 if memory serves. I think it comes with a new crank, oversized pistons, new rings, connecting rods, and a few other goodies. You'll just have to check it out for yourself.
You can do a 383 with regular pistons and rods and just a cast 400 crank for cheap. Just find a clean 350 that doesnt need much at the machine shop and your good for about 400 horse round about with some ok heads.
To ask the question "how much" is not realistic. How much it makes will be determined by the cam, heads, intake, and how much the internal components themselves can handle.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
well yes, it will make a difference, but dont expect a huge one. a small increase yields a small increase, in displacement to power terms.
you may be at a point where you're need to over-bore the block, instead of just stroking it. i dont know enough about the block itself the say whether you'd weaken it. i'm sure you would, but not significantly, especailly since the overboring to increase by 13ci is spread over 8 cylinders. that's only 1.625ci per cylinder over what the stroker makes. i think if you used that stroker kit, had the engine bored and some good sleeves/pistons/rings/gudgeon pins/etc fitted you'd still be on the safe side. i hope that's of some help.
can't bore or stroke a 350sbc to 396, 388 is its max. 396 is a big block anyway.
ahh, i see. im not too familiar with the Chevy engines.
(Here's where Babs comes in and says he could make a 350 into... like a 720CI fire breathing dragon that pushes 16000 HP and 25000 ftlbs of torque.)
and, a 400 crank into most 350s usualy requires quite a bit of machining to the support webbing area and shaving the main rails down to dangerously thin dementions. |
