Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-13-2006, 05:34 PM
DrivenSolo1988 DrivenSolo1988 is offline
Send a message via AIM to DrivenSolo1988
1990 5.0 mustang clutch tranny problems???????
a friend of mine has a 1990 5.0 mustang and for some reason when ur at a stop if u dont give it a little gas when putting it into first it will stall and if u put it into first slowly it grinds, all other gears work perfectly just first that is screwd up. does anyone kno if this is the clutch or tranny that is causing it and how can i fix this?? thanks
Old 07-04-2006, 10:16 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 1990 5.0 mustang clutch tranny problems???????
The grinding could be either a misadjusted clutch cable, bent shift fork, or bad syncros.
As for the stalling, could be a few things too. In need of a tune up, idle speed to low, TPS adjustment, dirty MAF sensor.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
