Old 06-13-2006, 03:59 PM
Colt Hero Colt Hero is offline
'97 Taurus GL, 131K: A/C Not Cold Enough
'97 Taurus GL 131K:
A/C doesn't seem as cold as it should be. After I verify that my blend door is tightly in the correct position (the actuator broke and I had the door tied up for the winter and now it's jammed down for the summer - but it might not be positively down), what are the A/C components most likely to be a problem. Is it just a matter of a shot of FREON? Should I consider completely bypassing the heater core for the summer? Hot coolant runs through it at all time which has to hurt my cooling capability...
Old 06-13-2006, 06:08 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: '97 Taurus GL, 131K: A/C Not Cold Enough
Place a small thermometer in the dash vent and see what the duct temperature is before you go replacing parts. Might just be the blend door you mentioned.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-13-2006, 06:11 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Well, since you have a '97, you won't want to add a shot of "Freon," but possibly R134a. Sorry, getting picky here.
Without knowing more about your situation, determining what the problem is is very difficult. Could be low on refrigerant, but you'd really need to know the pressures to determine that. It could also be a faulty compressor or compressor clutch. You could have debris restricting airflow through the condensor, or a cooling fan that is not turning on or with a bad blade that is not pulling enough air through the condensor and radiator. You might have a pressure switch that is out of calibration and not engaging the compressor for the proper duration. Or, it could be a combination of any of these.
Of course, you will need to remedy the blend door issue before troubleshooting much further.
-Rod
