Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-13-2006, 03:06 PM
capriceowns capriceowns is offline
Steering gear box
Few days ago, I had a weird leak.
Its coming from the RETURN line on my steering gear box, it leaked most of my powersteering fluid out over night, and The car wasnt moved barely.
We started it and it just leaks faster.
Is this real common? Im going to take the return line out and see if its corroded or anthing, but it was just a weird leak to suddenly pop up.
Old 06-13-2006, 03:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Steering gear box
Not weird, if the hose is old it could have failed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-18-2006, 04:18 PM
easterwabbit easterwabbit is offline
the return line is the low pressure one with clamps on it, not the hi pressure hydraulic pressed together one piece one
check condition of the hose especially at the clamps
it will be a very minor problem that even a monkey could correct
good luck
Old 06-18-2006, 04:51 PM
good luck
Yeah I know its the reutrn line, but its not leaking from the rubber hose, its coming from the fitting on the gear box, its a metal line then to a rubber one
I took the fitting off, and its kind of corroded, im going to buy a new metal pipe bend it like my old one and put it on and see if it still leaks.
Thanks.
Old 06-19-2006, 01:41 AM
silicon212's Avatar
Confoundingly Lucid
Thanks.
It could be the rubber O-ring seal on the interface end.
Old 06-19-2006, 10:35 AM
Is this on the gear box were the flared end goes into it?
Old 06-19-2006, 11:17 AM
silicon212's Avatar
Confoundingly Lucid
What year is your car? They stopped using flared ends in 1979.
Old 06-19-2006, 12:51 PM
mine is a 87, but the metal pipe i took off my gear box, has kind of a flared looking end to it.
is that just the way the pipe looks?
Old 06-19-2006, 02:14 PM
silicon212's Avatar
Confoundingly Lucid
They do sort of look like they may be flared, but they will have a shoulder on the "flare" end and the O-ring goes on this shoulder -
