Old 06-13-2006, 02:07 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
I think i know
Well, i have been debating for a while on what motor to put in my camaro when i get the money, but i think i have finaly decided tell me what you guys think. I am going to buy a rebuilt 350 bored .40 over so it is really a 357 and i am going to keep it tbi but use a big tb and injectors. I want to put vortec heads and rpm vortec intake on it also. With a good cam and heads and a good tune with my headers and exhaust i plan on making around 340-350ish?? But that is not all, i am going to bottel feed this baby. i plan on doing a 125 shot so it shoul put me to about close to 450hp? What you guys think? I did not forget about the tranny either, the local tranny place is going to race build it for me.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 06-13-2006, 09:49 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Re: I think i know
How much are you spending for that?
Old 06-13-2006, 10:14 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: I think i know
sounds like a decent plan. i was looking into that same combo myself, until I found out a few problems. Vortec heads don't have the head crossover for egr function I need to keep street legal. Also that intake manifold has stock tbi size bores, which will hinder some performance benefits the bigger bore TBI has to offer.
I ended up buying a pair of world products heads, but then the guy who did my engine machining suggested some aluminum brodix which I exchanged the world's for and they ended up not having the egr passage either, but I really like the heads, so i'm gonna just plumb the egr another way. The intake I got is a Holley Projection which is a TBI intake with the larger 2" bores to match the bigger TBI.
Old 06-13-2006, 10:16 PM
poormillionaire2 poormillionaire2 is offline
Re: I think i know
Instead of boring it, I would stroke it because a used block bored .40 over really weakens the cylinder walls. Plus you get more cubes out of a stroker. Just get a new crank and connecting rods and make it a ~380 or so. A good heads and cam will really make use of the extra cubes too.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 06-13-2006, 10:19 PM
Genopsyde's Avatar
The President
Re: I think i know
i'd bore it at least .030 over to clean up the walls of any imperfections.
Old 06-13-2006, 11:36 PM
97cavalier's Avatar
Re: I think i know
belive it or not i am getting the motor without the heads intake oil pan and all of that crap for about $1,200 shiped. i will probly go with world heads any ways i was just thinking vortec because of the rpm intake. I can get a nos kit for $500 and all i have to do is hook it up and get the bottle filled. but for the tranny, i don't know how much that is going to get me for. If it is to much i will just get one of thoes sizzler trannys out of the summit or jegs catolog.
Old 06-13-2006, 11:40 PM
97cavalier's Avatar
Re: I think i know
what i will probly do is keep my 305 mostly stock so i can save money. I will just get a good exhaust and put my headers on and maybe little crap like tb spacer and maybe the intake geo metioned so i will take it off the 305 then slap it on the 357 when i get it. I will get my car painted, then save for the motor and just slowly build it up.
Old 06-14-2006, 01:06 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: I think i know
What year is this 350? $1200 for a short block seems a little steep especially if it's gonna be bored .40 over. Around here you can get a remanufactured long block 350 that is garaunteed not to be bored more than .40 for a few hundred bucks more than that. Do you know the guy that is rebuilding this thing? Is he doing something special to it that makes it worth this much?
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-14-2006, 08:46 AM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Re: I think i know
hah... He called you "geo".
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 06-14-2006, 08:49 AM
Earlsfat's Avatar
Cheesesteakoholic
Re: I think i know
oh and... http://www.jegs.com/webapp/wcs/store...tegoryId=10763
Seems like you're gonna be in that price range (by the time you add the heads, oil pan, etc) with the same output at the end of the day. Why waste time?
Old 06-14-2006, 03:53 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: I think i know
sounds like my engine exactly (check sig). anyway... it's clearly a good setup, because i built mine based of months of research and cost/performance scenarios. I just haven't added my bottle yet. if you have the money go for it.
true, if you have a smog test in your area, it will be very difficult to get it to pass (I don't). don't know if you've added it all up, but it will be pretty expensive.
i would say no stroker kit, if you have that kinda money get AFR heads instead. and stroke it later.
boring it for the purposes of getting more cubes is a bad idea. don't go .40 over if you can avoid it.
note: vortec equipment is not interchangable with most other equipment. somethin to think about if you plan on changing.
you will need/want better torque converter considering the power range.
if you want a 125hp shot, i would go with forged pistons.
here are my mistakes that maybe you'll learn from. a couple things i have to go back and fix:
-go with roller cam instead of flat tappet.
-forged pistons
the only way i can tell you if this is a good setup for you is to know how much you want to spend... it's a good setup, but there is a lot of misc stuff u need to buy that will added significantly to your cost. and if you go over budget you'll have a nice project sitting in the garage instead of on the streets for quite some time.
if it cost too much, I can help you with a different setup.
i can also email you my parts lists (with the costs listed).
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-14-2006, 09:36 PM
97cavalier's Avatar
Re: I think i know
well actuly the guy who is going to be building it has a store on ebay and it a good seller. I just want a 350 that makes a nice solid 330hp or so. I want it to be about 450hp with the 125 shot. You guys tell me what u think. I will probly look for a rebuilt motor that is .30 over and i will have forged deep dished pistons put in it. How much you think that will run me?
Old 06-14-2006, 09:41 PM
97cavalier's Avatar
Re: I think i know
that motor on the jegs website would be perfect if it had forged pistons. And the town i live in has emmitions testing. But my dad lives one town over so i think say i live with him so i will have no testing.i WAS going to just get a 350 block from a junk yard but i just want some one to build it for me, or most of it i can do crap like put heads intake oilpan and crap like that on.
Old 06-14-2006, 09:55 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: I think i know
1500 dollars for a shortblock
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 06-14-2006, 09:57 PM
97cavalier's Avatar
Re: I think i know
$1500 with the forged pistons and every thing on it?
