Old 06-13-2006, 01:35 PM
Pimpdady753 Pimpdady753 is offline
carb help
ok i have a carb set up, and i have a tech, and i dont know witch wire the green wire goes to. i thought it was the black one on the coil, that was the wire i had it on when i had efi any ways, but it does not work. is carb different thanks.
Old 06-14-2006, 02:46 AM
brokenantimatter brokenantimatter is offline
Re: carb help
Why downgrade from efi?
Anywho the green wire goes to the negative ignition terminal or tachometer plug.....you should have a tacho plug.
Old 06-14-2006, 07:11 PM
Re: carb help
i do have a tech metear plug on my msd intion box, but i think its off or somthing, when i rev the engine it ses it only at 3000 rpm when it sound like its at 5500 or 6000 rpm, so i dont know,
Old 06-14-2006, 09:03 PM
Re: carb help
5500 - 6000 seems a bit high for a good 5.0 rev doesn't it?
What Tach and MSD Ignition do you have?
Old 06-14-2006, 09:24 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: carb help
I had the same problem with my car when I bought it. It had a POS nearly blowup 302 in it. Carb leaked, intake leaked, valve seals where shot, valve covers leaked, smoked BAD! (valve seals), ect ect ect. I could rev the poor thing till it floated the valves and the tach would bounce at 3k and not go any higher. This is a factory 4cyl car. I never bothered fixing the problem after I went thrue 6 quarts of oil in 15 miles.
1969 Cougar
357w & TKO - 475hp
Old 06-14-2006, 09:53 PM
Re: carb help
I owned a CVH Escort years ago.......many years ago.....
I threw a cam and decided to drive home on it (Almost 15 miles, 5 quarts oil, 8 gallons gas).............I miss that car.....it had a CD player in it.
Old 06-14-2006, 09:58 PM
Re: carb help
Digital 6 plus intion control Pn6520, and not sure about the tech its some off the wall brand i know that, but it worked in my old engine so i know the tech works.
Old 06-14-2006, 10:07 PM
351wStang's Avatar
Re: carb help
You are talking about a tachometer right?
1969 Cougar
357w & TKO - 475hp
Old 06-14-2006, 10:16 PM
Re: carb help
Okay you have a rev limiter try adjusting it to see if it effects your tachometer if not you might need to get a magnetic adapter. It would help if we knew the tachometer brand.
Old 06-15-2006, 07:12 PM
Re: carb help
um the rev limiter only works when a 12v source is sent to to the pink wire, witch i dont have hooked up, and i just looked all over the tech and it does not have any sort of brand on it,
Old 06-15-2006, 07:14 PM
Re: carb help
its this one
http://cgi.ebay.com/ebaymotors/7-COL...QQcmdZViewItem
