Old 06-13-2006, 01:25 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
someone wanna help me get the concept?
okay so what exzactly is tourque? i try to read about it but i dont understand how is it obtained is to much a bad thing what does it do exzactly can somenoe just tell me everything they know about it thanks
Old 06-13-2006, 02:39 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: someone wanna help me get the concept?
http://science.howstuffworks.com/fpte.htm/printable
That's the best way I can explain it...
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 06-14-2006, 04:23 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
torque in physics = r sin(X) F where F = force..or something like that. basically how much something has the power to turn.. hp is idk.. what is hp. lol torque is power. hp is..not really power..is it? O_o
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 06-14-2006, 04:42 AM
blindeyed's Avatar
eBay aDdict™
It's a unit of measurement. It's all explained in the link I posted above.
- Jason
Old 06-14-2006, 04:51 AM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
I'm gonna try, I've been thinking about this also. Horsepower is the soft part of an engine's power. When you're driving, horsepower makes the ride smoother, smoother gear shifting. But without torque the car won't move. TORQUE jerks the car violently forward when you shift wrong, it propels the car like nothing else. You need both torque and horsepower to have a good car, period. Does that help?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 06-14-2006, 12:44 PM
andyjs3589's Avatar
andyjs3589 andyjs3589 is offline
Send a message via AIM to andyjs3589
I heard this somewhere:
Horsepower is how fast you go through the wall and torque is how much of the wall you take with you
I probably messed it up but it went sumthing like that, that probably doesn't help you too much but I like the saying
99 Regal gs
Old 06-15-2006, 05:12 AM
mm. torque = kick in the a**
hp = speed? (in the end, i guess..since some small imports have crazy hp..but almost no torque..aka S2K.).. and they are pretty fast? i guess? idk..prolly depends on gears and such too(the torque part)
Car:
285's in the back
all else = STOCK.
Old 06-15-2006, 02:44 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
l dont know how to explain but l think this is it..
torque lets you go fast at low RPM.. helps the car pulls harder, better.. maybe l am wrong..
Old 07-03-2006, 04:21 PM
gmack221's Avatar
gmack221 gmack221 is offline
Torque is the force that gets your car moving ... Horse power is what keeps it moving while fighting against the friction (wind).
Like it was said above ... small imports have crazy hp..but almost no torque ... think of torque as pulling power ... you wouldn't pull a boat with a 4 cylinder vehicle ... because it has no torque, but a v8 handles a boat quite well. Diesel trucks have a ton of torque, but most don't have huge hp ... so you wouldn't want to race an import with a diesel ... but the diesel could pull a trailer with many imports on, lets see the import pull one diesel truck though!
very good subject, hard to explain ....
Old 07-03-2006, 04:56 PM
G-man422's Avatar
G-man422 G-man422 is offline
Thats how i would explain it.
Old 07-04-2006, 06:09 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Ya know...... torque!
Old 07-04-2006, 09:47 AM
troy1 troy1 is offline
AF -Advisor
HP gets you going and TQ keeps you going. just my
Old 07-07-2006, 01:02 AM
poormillionaire2 poormillionaire2 is offline
Torque is a measure of twist. Horsepower is purely a function of torque. But they are both different ways of measuring the same thing, go juice.
A dyno measures torque only. Then takes the torque values and plugs them into the equation and comes out with the horsepower. The equation is
HP=(TQxRPM)/5252
So, at 5252 RPM's, an engines HP and TQ ratings are equal. So, if your making 250 lb/ft of torque at 5252RPM, then you are making 250hp at that same RPM.
Hope that helps. If not, then torque is for burnouts and hp is for racing.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 07-07-2006, 01:14 AM
Oh yeah, torque is also multiplied by the gear ratios. That is why cars generally have more torque in 1st and 2nd gear than any other gears.
So, lets say your engine, at the crank, was making 50lb/ft of torque and you have a 3:1 first gear and a 4:1 final drive, then your torque at the wheels will be (50x3x4) 600 lb/ft of torque. But horsepower doesn't change with the gear ratios, like I said, horsepower is a function of torque and RPM. At the same time your torque went up 1200 percent, RPM dropped the same amount. Run through the formula at either end of the gear box and you end up with the same power.
I could go on and on with gear ratios and their effects on torque and stuff, but I won't. I hope that helps.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
