Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-13-2006, 12:11 PM
9-rodeo-6's Avatar
9-rodeo-6 9-rodeo-6 is offline
Keyless entry question
I was wondering if anyone knows how to tell if a 96 Rodeo has keyless entry. I bought it used and it has power locks. I've seen that you can buy key fob transmitters on ebay and I want to know if my rig has keyless.
Thanx,
Jason
2003 Grand Cherokee Laredo
4.7 L V8
4x4, Auto Trans.
Rochester, MI
Old 06-13-2006, 02:42 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Keyless entry question
Does yours have factory alarm? I think if it had factory alarm and power locks then it also had keyless locks. Pull the glove box and look to the right. See if there are 2 plastic boxes there (colors vary) one would be marked "alarm" (this is actually just relays and warning buzzer) and the other would be marked "keyless entry and anti theft".
I wasnt sure if mine had it or not either, I took the chance and ordered a remote from ebay and turns out it does.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 06-27-2006, 07:22 PM
boaz2020 boaz2020 is offline
I know on my passport you can tell by following this procedure.
1.) Make sure all doors are closed, and unlocked. Open driver's door. Insert key into ignition.
2.) Turn ignition switch to ACC position, then to OFF position 3 times within 5 seconds of step 1.
3.) Close driver's door and open it 2 times within 10 seconds after step 2.
4.) Turn ignition to ACC position, then to OFF position 5 times. Close driver's door, then open it. This must be completed within 10 seconds of step 3. If your doors lock and unlock after this proceedure you have keyless entry.
If it doesn't work the first time try a few times to make sure.
So in other words
OPEN DOOR
KEY ACC
KEY OFF
KEY ACC
KEY OFF
KEY ACC
KEY OFF
CLOSE DOOR
OPEN DOOR
CLOSE DOOR
OPEN DOOR
KEY ACC
KEY OFF
KEY ACC
KEY OFF
KEY ACC
KEY OFF
KEY ACC
KEY OFF
KEY ACC
KEY OFF
CLOSE DOOR
OPEN DOOR
Good luck!
-Phil
Old 06-27-2006, 09:15 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Instead of opening and closing the door the thousand times the procedure calls for, you can simply cycle the door slider switch.
2000 VW New Beetle TDI
2007 Honda CR-V
