Old 06-13-2006, 09:15 AM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
Steering problems
Recently I have noticed some steering problems. When driving my car pulls to the right very sharply. There is a constant vibration I believe from fighting the steering. Tires are rotated and air pressure is good. Any ideas?
Old 06-13-2006, 11:40 AM
Markgc's Avatar
Markgc Markgc is offline
Re: Steering problems
I'd jack it up and check the it. I'd look for broken or loose parts. I would check the wheel bearings and ball joints. I'd look for a loose or broken wheel. In fact I would take a good careful look at everything - cracked frame etc.
I wouldn't drive it like that until you get it fixed.
Mark
Old 06-13-2006, 12:26 PM
Thank you for reply. Wheel looks good. I jacked it up and checked all steering parts with the tire on. Everything looks good. No play in the wheel. I am going to take the wheel off tonight and check it that way. How would I know if the bearing is bad also is it possible that the brake could be sticking? I don't smell anything
Old 06-13-2006, 12:34 PM
Markgc's Avatar
I would check the bearing for play with vehicle jacked up. It would have to be pretty bad to give you the problems that you are seeingSee if the wheel spins easly. Check it with the engine running to make sure that the brake isn't binding but I think that would be unlikely to cause your symptons but not impossible. I saw a bad brake booster once that caused the front brakes to not release properly.
See if your wheels are running true. You might want to have the balance of the front tires check - a slipped belt or some other internal tire problem could give you bad problems. A tire shop will see this when they put it on the balancing machine. It could be a tire
Mark
