Old 06-13-2006, 02:20 AM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
Japanease readers! Please,read here,I need help!
Hey pepole!!!
I was looking around,and some doubts came upon me. I live in japan,so i have some little questions (sorry,i'm a gaijin,I dont speak nihongo.)
Do we have styrene in japan? I wanna mod my kits,but i dont know if they have styrene around here! I really need some! Shoud I search it in the hobby shop? Thanks!
And...Castrol Makes CSC around here??? I need CSC to strip some paint....Does anybody know?? Or something cheap that can be used in its place,that is not DOT2? (because DOT2 is expensive where i live.)
Thanks a lot!
"Oh noez,it has more stickers than me! And a wing too!
Old 06-13-2006, 06:05 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Japanease readers! Please,read here,I need help!
Okay, I'm not from Japan, but I'm using common sense when answering this.
1st. You should have styrene since Japan is the homeland of many model manifacturers.
So, yes. You should go to your LHS and will most likely find some.
2nd. I'm guessing you mean brake fluid when you say DOT2, then I would suggest alchohol
or oven cleaner (Note: Oven Cleaner doesn't work that well for me.). If you mean DOT2
when ya say it.. then I would suggest you find DOT3 or DOT4.
Under personal preference I would say DOT4. Haven't been able to find CSC here in TW yet.
HTH, Steve
Old 06-13-2006, 08:24 PM
rod_k2's Avatar
alcohol? Yes...But wich kind of alcohol? and,if possible..where can i find it?
Does it strip paint like brake fluid? Thanks alot!
Old 06-13-2006, 08:31 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Medicinal alcohol. Isopropyl is a favorite, but also try denatured. The higher the concentration, the better- use 99% if you can find it. It can frequently be had in grocery stores/drug stores/chemists in the US and Europe- I didn't look for it last time I was in Japan.
It will easily strip laquers and acrylics, and may work on enamels, too. Much safer than brake fluid.
Often, automotive cleaners/degreasers work well (this is what CSC is). Look for biodegradable cleaners. Some other brands it is sold as are Purple Power and Simple green- but I have no idea what it would be sold as in Japan. i suspect that orange smelling household cleaner stuff would work, too, but I haven't tried it.
PHOTOBUCKET SUCKS
Old 06-13-2006, 09:05 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
try evergreen styrene. i've been seeing them on japanese model magazines.
olly olly oxen free
Old 06-14-2006, 01:05 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Originally Posted by rod_k2
alcohol? Yess...But wich kind of alchohol? and,if bossible..where can i find it?
Matsumoto Kiyoshi, maybe? (Now that's hardcore)
But some Japanese motorsports fans might know what I'm talking about.
http://www.re-amemiya.co.jp/race/gt_01/s01_gt5_2.html
Or, you can try Mr. Thinner, because it's cheap over there.
As for styrene, Tamiya has been making them for decades, and all major hobby stores should have them. IIRC A4 size white sheet is available in 0.3, 0.5, 1.0 and 1.2 mm thick, and clear in 0.3, 0.5 and 1.0 mm. They also have paper thin styrenes, but they aren't so common. Styrene rods come in 2.0, 3.0 and 5.0 mm diameter (or the size of the sides for rectangular rods), and 30 cm long.
Also Evergreen's styrene products have been imported by Kyosho, and again they're not hard to find.
Now that's when you live in urban area. Depending on where you live, you might have to use online stores instead.
Hiroaki Fukuda
Old 06-14-2006, 06:19 AM
rod_k2's Avatar
mmm...MR thinner?? It strips paint????
Automotive cleaner...Biodegradable...Thanks! I will search that...and Styrene too! Thanks alot!
But i will try mr thinner...Should i dip the car in that,just like CSC?
Oh dang...I'm a giant and large NOOB! hehehe,but we have pepole that help the poor ones...lol!
Thanks alot guys!
Old 06-14-2006, 10:24 AM
cyberkid's Avatar
Erm, I would test a piece of sprue in Mr Thinner if you are going to soak it...I would recomend wiping the paint off with thinner and a rag (keep the thinner on the car for as short a time as possible).Or you can AB the thinner at a high psi, that kinda strips the paint as well (fast too).
We all were at some time! AF if here to help all us noobs learn
