| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
question about injector insulators leaking
ok so I just finished converting my n/t to a turbo, I have everything converted over although when I ease into the throttle right around 0 pressure on the boost gauge the car sputters really bad. Spark plugs are brand new and wires are 8.5 mm and fairly new. So I decided to check for boost leaks and Im getting an enormously bad leak through the injector insulators.(doesn't hold any pressure at all) I changed these when I put the 450s in but the one thing I noticed that was wierd was the lip on the injectors didn't press firmly into the insulators. there was about an 1/10" space between the top of the insulator and the lip on the injector. Now on my n/t injectors, the injectors actually left an imprint in the seals because they were pressed against them. now is there supposed to be another spacer in there around the injector. Or its almost like the fuel rail spaces are shorter on the turbo cars although I know thats not the case. What am i missing here?
Thanks guys |
Re: question about injector insulators leaking
1991 GSX 2.3 Stroker |
I'm sorry, should of been more clear, it was late when I was typing that message out.
Ok heres what I have, between the injectors and the fuel rail I have the small rubber o-rings which seal the fuel, thats fine. Then between the fuel rail bolts and the manifold I have the plastic spacers that always love to fall out when putting the fuel rail back in. Then the only thing I have between the injector nozzles and the manifold are the small rubber o-ring type seals that sit in the manifold (these are brand new). Now when I bolt up the fuel rail, the injectors don't press firmly into those seals (the ones that sit in the manifold), the injectors basically just sit in there, in fact you can kinda wiggle the injector back and forth a bit and this is where I'm loosing all my pressure. Now I did some research and I found with an injector seal kit you get the o-rings for the fuel rail to injectors, seals for the injectors to the manifold and also four plactic things, I don't have those and I'm guessing I probably need them, can somebody tell me what those are for? Thanks |
I think I understand what you're saying. Those little plastic spacers are a PITA, I've lost 2 out of 3. What I had to do was just eyeball it as best as possible when bolting the fuel rail down. It looks like you'll have to do without those spacers at all. I dont know much about nt to turbo conversions, but I would guess the measurements don't line up the same, something is longer, so you can't just bolt the fuel rail down enough to squeeze the injectors into the manifold. Just leave those spacers out, or find something that's a little bit smaller. Maybe those spacers come in different sizes?
now - 2000 civic soon - 2002 is300
Those seals are part of what keps the injectors stable in the manifold so they are definately needed.
Thanks for your help guys, I realized the rubbers I was missing when I got home so I just took them of old non-turbo injectors. I threw those seals over the injectors and they worked great! no leaks! also found a pin hole leak in my intercooler pipe. fixed that up with so JB weld and I was ready to boost! Holy Sh!t that car is now fast!!! I'm only running 8 psi of boost, making no knock what so ever and I can easily non keep up with my tsi buddies! If your not careful you can light the tires through the first 3 gears!! If you step on it in second gear going about 40kmph, once the boost builds my tires light up! haha I need wider tires now!! I LOVE BOOST!
Are you guys talking about the fuel injector grommets? Some of mine are pretty torn up and I'm hoping that's the cause of my intermittent rich misfire in drive with no throttle. I've already replaced the o-rings, put rubbing alcohol in the tank in case of excessive water and changed the FPR with no change(couldn't afford a fuel pressure tester at the time). It's either that or one of the injectors.
Black 92(6 bolt) Eclipse Auto N/T 2.0 K & N Air Filter, Megan Racing Strut Bars, 2.25 Mandrel Bent Catback, Unorthodox crank pulley, EGR block off plate, No balance shafts, KYB AGX struts and shocks, two piston GSX calipers 1990 AWD Astro Van Don't mod a car with problems. Don't swap parts without testing them.
Ya it turns out I forgot to install the grommets between the rail and the injectors. without these there or maybe in your case, torn, the injectors press too far into the fuel rail. this causes the injectors to not press firmly into the intake manifold and causes a major vaccuum/boost leak. If those grommets are causing a bit of a vaccuum leak it shouldnt cause a rich misfire. Correct me if im wrong someone, but you would be running lean. Can you elaborate a bit on the problem? really when you let off the gas, your car should get fuel cut inorder to drop the rpms because the idle switch should be grounded. Unless your idle switch isnt adjusted right and its causing fuel to still be injected with not enough air for complete combustion. The idle switch is the single wire sensor that is located right on the back of the throttle body. Unplug it and test to make sure it gets ground when the gas pedal is not pressed at all. let me know what you find
_________________________________ Nathan Car: used to be a 91 N/T Auto now a 91 Turbo 5 speed stock Tsi setup except n/t 9:1 internals 9 psi low/ 12 psi high |
I'm not sure I would use running alcohol, that stuff is at least 10% water itself, and up to 30%. The drygas type products are usually straight alchohol.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
![]() I also have an idle surge problem. I've tested all the vacuum lines and I had to replace the ISC as well. I've tested the TPS which works fine and I had to replace the oxygen sensor. I've tested the MAF as well as the resistance of the fuel injectors and changed the O-rings on them. I swapped the idle switch with a spare and no change. So perhaps it's out of adjustment, but it's not connected. When it is connected I can hear it make a noise and sometimes do some minor surging(in drive) when the throttle is not pressed.So what you're telling me is if I'm lucky all I need to do is adjust the idle switch and change the injector grommets. If that doesn't work I still have a few more options left though. Once I get it running right it's back to autocross I go to break something! I busted a brake line last time. ![]() Kevin, I'm glad to see you still post here. My friend said the 70% stuff would be ok but if the problem persists past the grommets I suppose I'll buy the real stuff. Doesn't Wal-Mart sell 99% percent rubbing alcohol though? If I can get my car running right and in good shape I'll consider myself ready to buy a GSX.
hmm well when the idle switch isnt connected the computer doesnt know when you want to idle and then it lets the engine run at any rpm. When the switch is triggered (when throttle is closed) the ecu tries to drop the idle but if there is to much air coming in from wherever (bad ISC, bad FIAV, vaccuum leak) it causes a visious cycle of fuel cut then injection, this causes the idle to bounce up and down. I know there's a little more to it but thats the just of it. Thats why when you have it disconnected you don't get idle surge. What may be ur problem is when you changed the idle switch you man have over tightened it causing it to actually open the throttle plate a bit at idle. This would definitely causes idle surge. The correct way to set the switch is as follows
Firstly make sure the throttle cable has a slight bit of slack, if this is holding the plate open thats another cause of idle surge. -loosen the jam nut on the idle switch then back the switch out until throttle plate fully closes -connect a digital volt meter, one lead to the idle switch pin, the other lead to a good ground -screw the switch clockwise until the meter registers continuity (basically until the switch is triggered). -turn the idle switch in 15/16 of a turn more from the point were continuity was detected. -hold idle position switch while tightening jam nut to ensure it doesnt move -adjust throttle cable again to ensure a bit of slack let us know how you make out
Get some ethanol (grain alcohol), but don't put it in the car....drink it and you won't care about the water in your tank.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
So I just did the idle switch adjustment and the throttle plate was cracked open a bit. So, I think that'll take care of that. My idle switch connector is about to have the wire disconnect from it though. I'm gonna find a junkyard one and put in some extra wire because there really isn't enough slack in the wire and that's why it's about to break. Also, I looked at the grommets again and they are totally fucked. Gonna have to call the dealer for that...
The guy that owned the car before me apparently had no maintenance schedule whatsoever. If this works out it'll be the first time that my car has run perfectly since I bought it in a little under two years. Thanks for your help guys, I'll keep you updated. You've been quite a bit more helpful than DSMtalk was.
Ok, so the improperly adjusted idle switch was the cause of my idle problems. Now, on to the fuel woes.
So, I went to a really cool junkyard with my friend and picked up some injectors for my car for $1 each. The grommets on those injectors were in good shape. I kept trying to attach the fuel rail but it didn't want to go and something told me things weren't right with the angle on the bolts and all. Well, I finally figured out that those plastic spacers are for between the fuel rail and the head. I don't know if those were on the car when I got it or not but at least I finally figured it out. Should've looked at the DSM manual more closely. Oh well, can't change the past.So, getting everything in order and getting the car running it misses and one of the injectors appears to be leaking. I take the fuel rail off and apparently the old o-ring failed so I swap it with one of my many injectors. So it appears to run fine so I take it for the 2.5 hour trip back to my house. It still run fine when the accelerator is pressed and a lot of the time when it's not pressed and just coasting. Thing is, it still misses like a mofo when it's stopped and in drive. I'm hoping this is just fuel fouled plugs. I'll change them in a bit. If not what could be some causes of this?
truely could be a 100 things! you said it only misses when in drive at idle right? is it fine in park? reason I ask is when the car is put into drive it creates a bit of a load on the engine due to the pressure in the torque converter. If you have a weak spark it could cause this problem. I would definitely do plugs! that would be the first thing i'd try. They seem to foul quite regularily in our cars. Since your a non turbo make sure you get the NGK BPR6ES-11 (11 stands for 1.1mm gap). theyre dirt cheap and work great. if that doesnt work look at your plug wires. If they are old or have never been replaced, I'd replace that with a nice set. They range about 30-40$ for a nice set. let us know how you make out
