Old 06-12-2006, 09:03 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
b16a fluids
hey guys with a b16a and cable tranny..do you kno how much oil, transmission fluid, and radiator fluid ill need to refill it?? im gettin this thing done tomorrow and have to get my fluids still.
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 06-12-2006, 09:37 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: b16a fluids
Oil is 4.2Q for a change and 5.1Q for a fresh build. (10w-30 or 20w-50 depending on climate)
Coolant is 5.0Q for a change and 6.0Q empty(50/50mix)
Trans is 2.2Q change, 2.3Q empty(10w-30 engine oil)
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-12-2006, 10:20 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: b16a fluids
if you want to run synthetic...run German castrol syntec. It only comes in 0w-30, but don't be afraid of the weight...it's actually more like a combination of 5w-30 and 10w-30. TRUST me on this one. It's better than mobil-1 synthetic, and has been tested to protect better and last longer than mobil 1, which tends to burn in hondas. I swear, you won't have any problems with this oil, like i said, don't let the weight scare you, it's misleading. Also, it doesn't oxidize as quick (black color). People who use mobil synthetic know what I'm talking about. That stuff oxidizes almost instantly. When you change your oil, it looks black and thin like water...yep, that's mobil 1 for ya.
I wouldn't recommend anything that I haven't tried myself. I recommend it to all my customers and use it in all my builds after they are broken in. I started using this oil after I put 500 miles on my freshly built lsvtec motor. My motor doesn't burn a DROP of oil, even at 9k.
Go to bobistheoilguy.com to learn more about it. It is comparable in quality to royal purple and redline oil. Let me warn you though, this stuff is expensive, but addictive. And, it's green! There's an interesting story behind why it's green, but you can find that at that website i gave you.
Sad thing is though, it's only available at autozone and walmart, and few other remote places.
If you don't feel like using synthetic, or you find that you burn synthetic, change to non-syn. Good non syn's include mobil one, and castrol gtx. Use 5w-30. If you have cold winters, use 10w-30 in the winter. DONT use any oil additives like marvel mystery oil or lucas...that stuff is junk. If you are STILL burning oil...it's time for a rebuild.
Honestly, I'd recommend this oil to anyone with a honda motor, unless you are currently burning oil, this stuff is amazing.
For an oil filter, i'd recommend using an oem genuine honda one and get an rsx type-s one. Believe it or not, when you buy oil filters for most hondas now, they'll give you that filter anyway, including all civics, crx's, delsol's, integras, etc. They got rid of the old larger style filters and sell every body the K filters for there B and D series now. They actually bump oil pressure up about 10-15 psi, which is good for vtec too. If you don't want to pay for a honda filter, get a mobil one filter for an rsx type-s. Of course, the older fatter style will still work, just give you slightly less oil pressure.
as for the coolant, prestone is good, but use whatever you like. Use a 70:30-50:50 mixture in the summer, and a 50:50-30:70 ratio in the winter (water to coolant ratio). Believe it or not, having a mixture higher in water will actually keep your car cooler. Anti-freeze is just that, so that your coolant doesn't freeze and expand in the winter, destroying your motor. Antifreeze wasn't designed to prevent overheating, but the opposite. That's why it is called "ANTIFREEZE"....lol. Antifreeze has a lower boiling point, doesn't exchange heat as good, and heats up faster than water. Don't believe me? There's a reason track only and race cars run 100% water...because it cools better than antifreeze. I run a mixture that is 20% coolant and 80% water. My engine management shows that my coolant is 4 degrees celcius cooler with the higher water mixture. You still need to use some antifreeze on daily driven cars though because it defends against corrosion and rust...which can destroy your water pump. Some people get away with this though and use a few drops of dish liquid in there coolant. It has glycol like antifreeze, which protects against corrosion. Keep in mind though, that if you use mixtures that are high in water, you have to change your coolant more often. No big deal, don't be lazy. Just change it at the end of the summer.
As for your tranny, use mobil 1 10w-30 synthetic or pennzoil syncromesh synthetic. They both work great. Honda mtf works good too, obviously.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-13-2006, 12:16 AM
Re: b16a fluids
how do i fill my transmission with fluid?? thru the top cap or what??
Old 06-13-2006, 08:12 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: b16a fluids
The VW dealership pushes the German Castrol synthetic stuff but they ass-rape you for it. We use U.S. Castrol full synthetic but VW has high mileage now and still runs pretty smooth.
I use a Purolator Pure-1 filter and I can only find the smaller one these days. I didn't know they bump up oil pressure but it makes sense. I use fossil oil Castrol 10w-30 so I don't really care much about it though.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-13-2006, 08:59 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: b16a fluids
Unless Honda has changed the internal material on their filters, they are still paper componants, just like Frams. Because of this I have stopped using their filters. Napa gold filters are built identical to Mobil 1filters, and are 1/3 the cost.
The US spec Castrol fully synthetic is not a true synthetic like they say. Thus the need for the german spec oil.
Old 06-13-2006, 12:31 PM
FrodoGT's Avatar
Re: b16a fluids
Your trans has two caps, you can put it in the top one.
Current project:
Rio Red 91 hatch.
Old 06-13-2006, 02:26 PM
bambam89lx's Avatar
AF - Advisor
Re: b16a fluids
yep, the German castrol is not the same as the US made castrol. The real german castrol ONLY comes in 0w-30, and is GREEN.
also, fram's are not the same as honda filters. Not even close Kris. They do use the same paper filter, but that's it. Do the research on bobistheoilguy.com...it has absolutely EVERYTHING you need to know about oil and any filter man ever made. I don't feel like writing it all out because I've got a short lunch break....lol.
Old 06-13-2006, 02:27 PM
bambam89lx's Avatar
AF - Advisor
Re: b16a fluids
also, for filling the tranny...you can fill it in two places, either through the speedo drive, or through the fill plug to the left of the passenger axle. Fill until it starts to pour out.
Old 06-13-2006, 09:52 PM
FrodoGT's Avatar
Re: b16a fluids
Since youve already got the speedo drive out, its a much bigger hole and easier to reach, thats how I did mine. Just make sure the upper plug is out on the side or youll end up filling the whole tranny.
Current project:
Rio Red 91 hatch.
Old 06-14-2006, 12:49 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: b16a fluids
what? so i fill from the speedo sensor spot after removing the side cap. then fill till it is full? sorry i had the same question
Old 06-14-2006, 12:53 AM
FrodoGT's Avatar
Re: b16a fluids
Yeah remove the upper side plug so that you know when it is full, and pour in from the speedo drive hole, when it comes out the side hole its full.
Current project:
Rio Red 91 hatch.
Old 06-14-2006, 01:05 AM
kris's Avatar
Re: b16a fluids
They must have changed their design within the past few years then.
Old 06-14-2006, 01:10 AM
Re: b16a fluids
ok guys solved my shift linkage problem..the pin was stuck in there and my punch snapped in it so its gonna be in there a while. thanks to a little good luck i noticed the new linkage had a removable bolt so i just added 2 washers and it works perfectly..had to go to the acura dealer for a bushing and washers for the stay arm and that set me back 20..got all my hoses, fluids, tees, bolts, and a breather filter for the intake..another 100 and the bastards at autozone wouldnt give me two punches to get a free 20 dollar card since it was one transaction..ive went there for my whole swap for the most part and they couldnt do that for me..the fill plug is just to the left of the passenger axle insert and its not hard to fill.we just the hoisted the engine a little to put a funnel in and slowly fill..did take about 2.3Q cuz i put in a little more and it came out when i lowered it.
ill post a pic tomorrow of the beast sittin in the engine bay..its not all bolted in yet cuz i still gotta do a little more grinding on the crossmember to make way for those headers. idk how my radiator is gonna fit with that small fan on the drivers side. what is that one used for??
Old 06-14-2006, 01:51 AM
bambam89lx's Avatar
AF - Advisor
Re: b16a fluids
AC fan. Get rid of it.
