Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-12-2006, 07:43 PM
vtwindave vtwindave is offline
Thumbs down 95 gm 4.6 surging
i have a 95 gm with a 4.6L, 83,000 miles. the engine surges when first started cold. it has NEW plugs,wires,fuel filter, iac valve, no vaccum leaks found, cleaned egr passage & installed new gaskets. also has new crank pos sensor & ignition module. fuel press is good. surging goes away after brief warmup. any thoughts on what maybe causing this????????????????????
Old 06-20-2006, 08:56 PM
radioman2002 radioman2002 is offline
Re: 95 gm 4.6 surging
Possibly a bad or intermittant temp sensor. Not the one for the guage (if equipped) but the one that the PCM uses.
Old 06-20-2006, 11:56 PM
i was wondering about that myself, i'll change it and llet u know, thanx
Old 06-26-2006, 12:39 AM
well i put in a new temp sensor (for the pmc) and no help still surges when u start it cold and the engine ildes down from startup. any other ideas???????? i was hoping the comp would log a fault and give me the check eng light but no luck.
Old 06-28-2006, 11:00 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
make sure you intake zip tube is connected properly and not leaking also when was the last time you cleaned the maf?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 07-15-2006, 05:35 PM
i cleaned the maf when i changed the iac, not long ago, the tube is connected ok. do u know if a maf from a v-6 will work on a v-8? i was thinking of getting a maf from junkyard. also, would a aftermarket crank position sensor give you problems rather than one from ford???? thanx
Old 08-29-2006, 06:09 PM
after pulling my hair out, it was the ignition module i purchased from auto zone that was causing my problem. i replaced it with a stock ford one i got in a junckyard, problem went away!!!!!!!!!!!!!!
