Old 06-12-2006, 04:08 PM
justinp01 justinp01 is offline
Rack and pinion leaking
I have a '01, 5.3L, 2wd, 80k miles and my rack and pinion has been severly leaking on sharp turns. I looked underneath and it seems as though I have a hole in one of the boots that covers the inner tie-rod.
Does anyone know if replacing this boot should fix my leak?..
any help or suggestions would be great....
Old 06-12-2006, 04:14 PM
maxwedge maxwedge is offline
A990 racer
Re: Rack and pinion leaking
Boot is a dust seal only, the leaks are from the rack end seal most likely, you will need an exch rack, unless you can get this done as a seal only job at a dealer, as they have the specific tools to do this job.
Old 06-14-2006, 02:43 PM
Well its at the dealer now.. but they said that once it starts leaking that it should be replaced b/c the internals could be damaged.
Anyone replace one before? What would be a reasonable quote? I know just the rack is $450. I would probably get it done alot sooner if the dealer does it.
Old 06-14-2006, 04:23 PM
A990 racer
450 for a GM reman rack, sounds awfully cheap?
Old 06-15-2006, 03:27 PM
It just got finished, $450 for the rack only 3hrs for labor and $60 for a realignment, ended up being $850 after tax...
I'm hoping the rack is new, but I am not certain....
