Old 06-12-2006, 10:45 AM
NiteRanger0 NiteRanger0 is offline
How many miles to reset codes?
I have a '97 Lumina that failed Stated Inspection because the Check Engine light was on (Cam Timing Sensor was bad). How many miles do I need to drive the car so that the computer will totally reset it's codes?
Thanks!
Old 06-12-2006, 10:58 AM
maxwedge maxwedge is offline
A990 racer
Re: How many miles to reset codes?
Thanks!
Drive cycle requires a cold start , drive a t 55 mph for a few minutes, idle for a few minutes, slow down from 55 without braking, between 1/4 and 3/4 tank of fuel also. The inspection station can print out a generic drive cycle for you that is more detailed.
Old 06-12-2006, 02:26 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
just un hook the negative battery cable. the car will run a little different afterwards while it learns its new parameters, but it should get rid of the light.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-13-2006, 10:26 AM
OK, I didn't really get the answer I was looking for. Just as an FYI for others with this same problem, I took the car back to the Inspection Station after driving it for 100 miles and it passed inspection so the magic number is 100 miles or less.
p.s. The mechanic had already cleared the "Bad Cam Timing" code, I was just wondering how long I needed to drive the car before the car went through all it's self tests and realized everything was OK.
Old 06-13-2006, 10:39 AM
tblake's Avatar
In God We Trust
that would be a single complete drive cycle as stated by maxwedge
Old 06-20-2006, 07:30 PM
radioman2002 radioman2002 is offline
New York has the same crap, not that it was anything to do with anything except to generate more money for the state. My inspection station guy says, it's different for every car, he had a Ford that he reset and it passsed after only 10mi.
Apparently a common eroor code, same for my car, $50.00 for the sensor and 20 min for the work to change it. Well worth it not to have to deal with it the next inspection time.
