Old 06-12-2006, 07:22 AM
spmiller spmiller is offline
Intermittent dashboard Battery Light
Driving home on the highway last night, got an intermittent battery light on the dash. Not on solid, kind of half way, sometimes went away. Headlights were very weak.
When I got home I put a voltmeter on the battery with the engine off, read a little under 12v. Then started engine, and read just a little over 11 volts. If the alternator is fully working, shouldn't it read about 14V?
Anyhow, trying to figure out what went bad. I also see on the motocraft website that you can just replace the alternator regulator.
Suggestions?
thanks
Old 06-12-2006, 09:17 AM
phil-l phil-l is offline
Re: Intermittent dashboard Battery Light
Yes, when the engine is running, the vehicle's voltage should be in the 14V range. Your reading of 11 volts means the van is discharging the battery while running. Generally, this means the alternator is bad.
Hmmm - I'm not sure about the just-replace-the-regulator question; I believe the regulator is part of the alternator.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 06-12-2006, 11:44 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Suggestions?
thanks
Hello
Before you replace anything...check the small wire going to your alt. Mine was loose and giving me a intermittent light.
Edit***---I had a Ford Alt. tested at an auto parts and they said it was bad....it turned out (after replacing the alt, that it wasn't bad) that I didn't get the plug put back all of the way for my dash unit when I had it apart...that caused the charge light to come on.***---
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 06-12-2006, 12:24 PM
DRW1000 DRW1000 is offline
A lot of auto parts retailers will bench test your alternator for you. You need to remove it and bring it in but it will take the guess work out of it.
I have replaced regulators internal to the alternator. Sometimes they are actually installed on the back of the alternator.
You could also have a bad cell in your battery that iss draging the system voltage down. However 12 Volts when not running though seems to indicate an uncharged battery more than a bad cell.
Old 06-12-2006, 06:35 PM
wiswind wiswind is offline
Sometimes, the battery can go, causing a big load on the alternator, causing the alternator to seem bad.....or even go bad.
If the battery is 5 years old, or more, I would replace it.
On my '96 3.8L, there is a fuse "T" in the engine compartment fuse / relay box that can blow, causing the alternator to not work.....So I would also check that. It is one of those mini plug in fuses.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-14-2006, 08:44 AM
garync1 garync1 is offline
From what I understand some older models had a external regulator. The easiest way to check is to go to Advanced Auto or Auto zone and let them check both in the car with a load machine battery alt tester. Its free. If you live far away from one,you may want to pull them out and carry them in .its alot more work but it should solve your problem. They can test both in the store as well.. Hope this helps..
Old 06-14-2006, 12:12 PM
ricebike ricebike is offline
to avoid lesabre's experience, check that wire... then have autozone/advance autoparts test your alternator/battery in the parking lot for free...
