Old 06-12-2006, 05:30 AM
pirata12's Avatar
pirata12 pirata12 is offline
Help with white paint
Hi
I've started a Suzuki RGV with white rims. I've primed them with Tamiya primer. However no matter what I do I can't get the gloss white to cover the rims. The edging shows through and the rest seems to attract the white paint to the centre if you know what I'm saying. What should I do?
Old 06-12-2006, 05:45 AM
mickbench's Avatar
mickbench mickbench is offline
Re: Help with white paint
I know what you mean... Mostly, its down to applying the white too thick in one go. Have you tried laying it down in many mists first?
Also, if your primer is pure white, and it looks totally white, and you're happy, you can actually just clear the white primer... Primer covers better anyhow... Just an idea thats all..
Old 06-12-2006, 05:48 AM
pirata12's Avatar
I'll try that Mike. My primer is grey and when I tried the fine mists it just looked like clear coat. I guess I'm going to have to let the rims soak in brake fluid tonite and start over. I was even looking to see if Suzuki used a darker rim for any race in that season but alas!
Old 06-12-2006, 06:55 AM
freakray freakray is offline
AF Modelrater
Grey primer is the wrong thing to be under white paint.
It's been covered here 1000 times, white paint is semi-translucent so you need to put down white primer under it. If you can't get white primer, use matt white as a base coat, matt white is more opaque then gloss white.
AF User Guidelines
Old 06-12-2006, 07:00 AM
pirata12's Avatar
Thanks! Sorry I didn't look elsewhere.
Old 06-12-2006, 02:09 PM
wouter1981 wouter1981 is offline
yep.. white primer, or a different primer with a matt white basecoat is the way to go. Al those light colours, with yellow,... need a matt white base coat
