Old 08-01-2002, 11:45 AM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Header Question
r headers 4 the DX & SI hatch the same? I need to know cause there is always stuff on ebay and it just lists 88-91 civic.
thanks
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 08-01-2002, 12:28 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
pretty much all the d series are the same. just little tweaks here and there that made them different. i took my header off the 89 Si's d16a6 and put it on the '00 Ex's d16y8. so i would assume it will work. i know eric has a 88-91 version on his zc.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-01-2002, 12:50 PM
dfarres's Avatar
Question Check this out
here is one of the headers i was lookin at......if i plug the o2 sensor hole at the end, it should b cool 4 my DX ...... right?
ebay header
1993 Civic Coupe EX
Old 08-01-2002, 04:59 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
I dont think that header would work for you because it says for DOHC motor or 92 and above DX etc...
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 08-01-2002, 05:12 PM
amy@af's Avatar
i would e-mail them and point out the typeo. there was no 88-91 dohc (except for the JDM SiR b16...and they were talking USDM product).
i think it will work. it's talking about sockets for the o2 because after 91, they changed it a little (newer engine have a 4 wire o2 sensor). as i mentioned before, from 88-00 the bottom end is basically the same. so the same shape header can be used because they made a provision for the 4 wire sensor.
again, i took my header off the 89 d16a6 and stuck it on the 00 d16y8 with no troubles.
the key is to buy d series parts for a d series block...b series parts for a b series block. other part that fit 88-00 are cam gear & under drive pulley to give ya an example. honda was very smart to keep it interchangable...little money is spend on design and yet the part fits several years...if it isn't broke, don't fix it
Old 08-03-2002, 10:14 AM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
Hey its true its damn true..i had the same ? when i ordered my header..after i ordered it i was like oh damn that was for the 1.6..cuz im kinda new to this whole import thing being only 17...but then when i got it and went to put it on..it fit perfect...im not sure if all headers work like that but Pacesetter headers do..well in my case it did.
