View Poll Results: Do you utilize the Smith Machine?
Yes, I regularly use it for numerous exercises 0 0%
Sort of, I only use it for 1 or 2 specific exercises 3 60.00%
Never, I'm not a fan of the machine, or I've never tried it 2 40.00%
I'm too scared to venture into the freeweight room 0 0%
Voters: 5. You may not vote on this poll
Old 06-12-2006, 12:10 AM
tenguzero tenguzero is offline
Smith Machine
So, I'm generally a fan of the Smith Machine at the gym for a couple exercises (it's the piece of equipment that has the bar set into a vertical track that allows you to latch it off at various levels, and is generally a "safer" way to utilize free weights.) I use it for bench presses (I almost always go to the gym by myself, so I don't have a spotter) and squats (I feel like I can get a deeper squat with it) -- everything else (deadlifts, lunges, etc.) I use freeweights for. Now, I'm well aware of the arguments both against it (unnatural tracking motion for the body, takes away from some of the glory of "stabilizer" muscle training) and for it (safer way to utilize free weights.) What's the opinion around here?
Also, if anyone can give me a definitive answer on what the actual bar weight is on a Smith Machine (unless the counterweighting mechanism varies from model to model) I'd like to know, because I've read and heard everything from 10 pounds to 40.
(k) TZero publications. All rights reversed. Reprint what you like. Fnord
Old 06-14-2006, 11:43 PM
shizznizz980 shizznizz980 is offline
Send a message via AIM to shizznizz980
Re: Smith Machine
I like doing squats on it. But whenever I do bench press it feels wierd
Old 06-15-2006, 01:18 AM
Igovert500's Avatar
blue + red light magnet
Re: Smith Machine
Love it for squats, that is about it. My housemate got one cheap, and I used it for bench and military press, etc. but I really prefer freeweights for that. But for squats, I definantly love it. I've always thought the bar was 45
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-15-2006, 03:39 PM
Re: Smith Machine
Yeah, the bar is 45 -- but the machines (at least at my gym) have this sort of counterweight mechanism in them. It's kind of weird (I'm not sure if it actually affects the dead-weight of the bar.)
Old 06-20-2006, 11:23 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: Smith Machine
well, for my estimate, i'd say about 20 lbs including the counterweight. My benchpress is about 20 lbs different when I do it on the smith vs free weight. It may be even less since you use less muscles to stabilize.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 08-10-2006, 11:16 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Smith Machine
I would only use it if i needed to because i didn't have a spotter. You can also use it to do different squats to target different muscles. that's about the only thing i'd use it for.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 08-19-2006, 11:05 AM
Re: Smith Machine
I just used it on wednesday, I can't lift nearly the weight i do on a normal bench press but i find i have the confidence to do more reps because i know that the bar will be held in place, when i got a spotter at school, the weight was sometimes 40lbs heavier than they were so i didn't feel like they could stop it from crashing down on me. i guess it's good for targeting only the pecs because i didn't feel it anywhere else. it might also be that i wasn't using proper form on the normal benchpress to pull in more muscles.
Old 08-26-2006, 03:24 AM
cody_e cody_e is offline
Send a message via AIM to cody_e Send a message via MSN to cody_e Send a message via Yahoo to cody_e
Re: Smith Machine
I'm a 100% freeweight guy. I think you can build the most strength by having all the muscles involved (stabilizers) and the only reason for machiens is for rehabing.
Old 08-26-2006, 09:23 AM
Re: Smith Machine
or if you don't have a spotter, i would much rather get a spotter and be able to do a normal benchpress. until then i'm gonna stick with dumbells, i would rather do a benchpress but these will do until school starts (my university has an awsome athletics department and an awsome gym, so i'll probably find a training partner)
Old 08-26-2006, 12:02 PM
Re: Smith Machine
Oh yeah make sure you have a spotter. I used to lift in my room all the time by myself and I had a special way of getting the bar off my chest (granted this was 8th grade and I was repping like 120). Dumbbells are a great alternative and they help build the stabilizer muscles even more. The only problem I have with dumbbells with bench is I maxed them out. At school they only have 80 pounders as the highest weight. I just started doing higher reps with them. I ended up doing like 20 reps! I also have some adjustable dumbbells that I can only fit 80 pounds on (unless I were to put a 25 on each end but that would be impractical. I guess in metal class this year I'll have to fabricate some bigger adjustable dumbbells.
Personally now I haven't lifted in about a month. I got a job doing physical labor work in the cheese factory (haha good old Wisconsin ) and I work 9-10 hours a day. Shoveling cheese is a great workout. My arms and shoulders are getting bigger even though I'm not lifting. If you want to get paid to workout you can always get a job that requires a lot of physical labor
