Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-11-2006, 10:22 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Timing belt tension question
Ok, so when setting the tension on a timing belt, you bolt the auto tensioner on, then use the special tool to set the gap on the tensioner, hand turn it over 6 times, and THEN pull the pin on the auto tensioner? Is this right? If not, can anyone tell me the right way?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-11-2006, 10:34 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Timing belt tension question
i used the old tensioner in and compressed the shock if you wnana call it that, put the belt on and pulled the pin out of the shock, it set it self, that car saw 130mph later that week then ebay the next! Then off to ohio it went! lol
Old 06-13-2006, 12:35 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I've never used the "special tool". I just set the tension with a torque wrench (non-clicky type) and then set the tensioner so it's up against the arm thingy and then pull the pin out. Works for me every time.
95 Talon TSI AWD
97 Eclipse GST
