problem shifting
i'm having a hard time shifting into third gear from second. it won't go! sometimes it goes if i have the clutch fully down but other times even with the clutch fully down it won't shift into third. does anyone know what may be wrong?
Re: problem shifting
Probably a syncro.
![]() Try double clutching. |
could be a synchro, do you hear grinding??? How's your tranny fluid?? if it's due for a change, maybe some redline or royal purple'd do the trick till you can fix the synchro
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
doesnt sound like a synchro problem. usually synchro problems are about grinding, not being able to shift at all
This is risky shit, but you can do it to find out if your synchros are okay... what you do is when your in second drive normally up until about 2000-3000 rpms and push on the shifter like you are going into third with it, but don't use the clutch, and give it some power (with your hand that is) and try to power it into 3rd gear. If you can do all of this, than your synchros are fine, but if you hear any grinding at all than it's something else.
i agree with Young. bad synchros will give you a grinding noise. not being able to shift is usually a problem with either the master or slave cylinders.
when my slave cylinder went out, i could shift sometimes, and not others. i would assume if the master went out, shifting altogether would be impossible. but i would check your master/slave cylinders for leaking clutch (aka brake) fluid. the master cylinder is located in the engine bay, drivers side, up top by the brake booster, its got a little circular top. master cylinder pic at the bottom of this page, last pic http://www.stealth316.com/2-clutchbleeding.htm ![]() the slave cylinder is harder to get to, but most easily accessed by removing or pushing aside the intake pipe, b/c its just on top of the transmission. slave cylinder (in pic marked 'release cylinder'). notice the 'release fork,' this will help you identify the slave cylinder pics on this page http://www.stealth316.com/2-clutchhose.htm ![]() in this pic, #19 is the slave cylinder ![]() www.stealth316.com will provide you with more info and pictures to locate these cylinders.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit Last edited by Linebckr49; 06-13-2006 at 07:58 PM. |
^just FYI your pics arent showing bro. Link works though...
well talk to Jeff Lucius, then, b/c my html code is correct, and the image links are correct, and when i preview my post, all the pics show.
maybe i'll include links to those pages where the pics are. EDIT: ya, sometimes when i refresh the page, teh red X's appear, other times the pics appear. go figure.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
pics work for me.
CHeck your fluid, your cylinders, and then perhaps it's time for a tranny/drivetrain oil change. http://www.stealth316.com/2-awddrainfill.htm If it's been 60k or more since you've changed your drivetrain oils, it's definantly time.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. Last edited by Igovert500; 06-14-2006 at 04:44 PM. |
for anyone who cant see the pics above (like my sorry @$$)
master cylinder ![]() in this pic, #19 is the slave cylinder
lol still cant see it
They show up fine for me, both times, but if you can't see them, here are the links.
http://www.stealth316.com/images/mastercylinder.jpg http://www.stealth316.com/images/hose.jpg http://www.stealth316.com/images/clucthmanpic.gif
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
