Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-11-2006, 05:11 PM
divemaster divemaster is offline
High speed mode of Cooling Fan
Hello again!
My 99 Transport 3.4 does not want to run the "high Speed" mode of it's cooling fan. I have hooked up a scan tool - and tried to force the high speed mode of the fan but can only activate the low speed setting.
The guage needle is climbing around the 100 mark - should be at the first mark and staying there! If I drive it - the temp comes down...
Any thoughts???
Thanks in advance,
Shane
Old 06-11-2006, 05:37 PM
GregA's Avatar
GregA GregA is offline
Re: High speed mode of Cooling Fan
Hey Shane,
There are three (3) relays involved for the fans, but one is "special" for high speed mode. I have some details about the system at the link below, including a schematic. That should help some.
Cooling Fans
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 06-12-2006, 09:18 AM
Thanks very much! I will work with this and let you know how I make out.
Old 08-06-2006, 10:58 AM
Thanks for the help. I tested all of the relays and fuses - even checked all wires - still nothing. It appears that the engine also stalls the second the high speed fans try to kick in. There are no codes being tripped - just a stall. Once the engine cools - it will start right up again...
any other thoughts?? I am thinking computer but it is expensive and once you buy it you can't return it..
again - thanks!
