Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-11-2006, 04:32 PM
girliebomb girliebomb is offline
another question for the pros!
ok what happens or what are the symptoms when your overdrive goes out?
Mine does all that sputtering and stuff when the over drive button is engaged.
THanx again
Old 06-12-2006, 11:41 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: another question for the pros!
What? I have NO idea what you're trying to say/ask here. A little better question and description of what's going on will help tremendously.
95 Talon TSI AWD
97 Eclipse GST
Old 06-13-2006, 09:51 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Do you even know what the overdrive is?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-14-2006, 12:58 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Maximum Overdrive!
1991 GSX 2.3 Stroker
Old 06-14-2006, 01:09 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
So when ovedrive is on it acts weird? Overdrive conserves gas it is a different gear for 5th so it helps mostly on highway, i think it also tells the tcu to shift sooner. If it only does it when it's on leave it off or vice versa.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 06-15-2006, 10:35 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
actually overdrive makes the gears longer. If your driving at lets say 70mph at 2900rpm with the over drive on and the turn it off without changing anything else your rpms will go up to like 3400. Thats all it does nothing special just makes the gears longer
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-15-2006, 11:38 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Overdrive isn't another "gear". It's a clutch inside the torque convrter that when locked in, prevents any slippage, which improves fuel economy and lowers the transmission fluid temp. As far as the "sputtering", i'd say it's a misfire during high load situations. Changing the plugs, wires, distributor
cap and rotor (or coil pack) should fix the problem.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 06-16-2006, 11:19 AM
blk_srt's Avatar
I didnt say it was another gear I said it acted like it. And in some situations it is another gear like with an external over drive on a rwd application.
Mods:
Old 06-20-2006, 10:07 PM
kjewer1 kjewer1 is offline
AF - Advisor
Overdrive is not simply a locked TC, though the TC will typically only lock while in overdrive, since it needs to be unlocked to shift. In more modern transmissions the TCU will lock the TC in other gears as well, and automatically unlock it for shifts. My dooley for example would lock in 3rd and 4th. The newer models could lock the TC as low as second gear.
In most cases of 4 speed autos, there are only 3 "gears" provided by the planetary gearsets. Overdrive is an additional mechanism that provides further output rpm multiplication (less torque multiplication). It uses a seperate clutch band, that can often fail (usually from people doing a lot of city driving with OD engaged, so it shifts in and out OD constantly). When this clutch is failing, it can surge a bit as it slips/grabs. If it's acting strangely when the car is going to slow to engage OD (usually around 45 mph or so) then something else is going on, probably with the TCU or something, but this is all well out of my personal eperience/knowledge.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
